Question about GPS
I have a NavSure 200i. The batteries are fully charged, and I have not knocked or dropped it. Ehen I turn it on, instead of the normal boot-up screen, I get various blue screens with an options menu - ie : UTool Oscar90C R03 512MB 0=FlashRom Upgrade 1=GPS Tools 2=Other Tools Choice: 0 There are other screens with similar menus. Regardless of what I do, I cannot get gack to the normal boot-up screen. I have ried to press the Reset button at he top of the unit, but nothing happens. I have tried to re-install the software, but it will not allow me to do this. Help. Bhupendra Solanki
My kindle fire does not keep its charge. I can use it one time and during the ap it goes dead
If you charge the device fully, meaning 100%, and while using it with a simple app it doesn't last 2 hrs. then you need to replace the battery. Next time it goes dead, don't turn it on, instead plug the charger and let it charge to 100% while the device is off. Once is fully charge, use it as you would normally do. But still,it needs a new battery.
Apr 30, 2015 | Tablets & eReaders
Tip
Notebook Battery Tips
<span> <p><b>Instructions:</b><br /> <p><br /> <ul> <li>New battery pack must be fully charged before use.</li> <li>New battery pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity.</li> <li>Rechargeable batteries undergo self-discharging when left unused. Always store a battery pack in a fully charged stage for storage.</li> <li>Fully drain and fully recharge your battery pack every few month.</li> <li>Turn down the LCD brightness of your portable device.</li> <li>Use built-in power management on your portable device.</li> <li>Turn off LCD or other unnecessary accessories when not in use.</li> <li>Set screen saver blank to 1 to 2 minutes of your notebook</li> <li>Add more RAM if you have extra RAM expansion slot, it will reduce the usage of hard drive and it is power exhaustive.</li> <li>Close unused software in your notebook.</li> <li>Remove unused PC Cards or USB devices from your notebook.</li> <li>Don't watch DVD or play graphics intensive video games.</li> <li>Don't short circuit terminal or store your battery pack with metal parts.</li> <li>Don't drop or mutilate the battery pack.</li> <li>Don't expose to moisture or water.</li> <li>It is normal to get warm when charging or normal use. If it is getting too hot, there may be a problem with the device and qualified personnel should check it.</li></ul></span>
on Nov 03, 2010 | Computers & Internet
My motorola droid x turns on then after booting up it powers off even with a fully charged battery
It's best you contact Motorola support for troubleshooting. That doesn't sound normal.
CONTACT US
Mark
Motorola Support
Jul 25, 2014 | Motorola Mobility Droid X
1). Dropped MacBook Pro (While off, Battery Fully Charged, Normal working condition) 2). Turned on to see if okay... 3). Heard it begin to boot up like it normally does... 4). Immediately turned back...
Very difficult to tell what could have go wrong. Could be a connector, could be a chip. Even a flatcable or a motherboard can be dammaged. Online you can get service manuals and there are video's about how to open and close Macbooks. Still I do have to advice not to open a laptop, if you don't have any skills in repairing electronic equipment.
Oct 30, 2013 | Apple MacBook Pro Notebook
Can a battery read 12volts when engine doesn't start and if lights get turned on voltage drops to 3 volts does this mean the battery is no good
Your battery is definately suspect.Give it a good charge and check it again. If it drops like that when you turn on the lights replace it.A fully charged battery in good condition will read about 14.2V when fully charged. When you turn the key to start it will drop to about 11 and come back up when you turn the key off.
Aug 30, 2013 | 1999 Ford Econoline
My tomtom can't find GPS position quite often
change the battery or make sure it is fully charged ehen you use it all intermittent failures are usually related to low battery power
Jun 29, 2009 | Tomtom ONE GPS Receiver
Nikon coolpx L5 turns off when taking photo
Did you drop your camera? Did it get bumped or knocked around? It sounds like either you have a senor that is out of alignment or going bad, or you dropped your camera. Did you check you battery? Is it fully charged? If you want to fix your camera, I have a friend who fixes them.
http://www.cameradr.com/
Jan 03, 2009 | Nikon COOLPIX L5 Digital Camera
Purchased new battery, now NOTEBOOK won't work on battery after full charge
Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
Feb 13, 2008 | Toshiba Satellite A45-S250 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
GPS Logo
188 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
