Question about Car Audio & Video
Technika FM In-Car Transmitter loud low frequency hum
I am using this Technika FM In-Car Transmitter for the first time; it is easy to use and works except that the music is accompanied by a low frequency hum. It is continuous whether the music is playing or not whether the mp3 is connected or not and even when the car engine is not turned on. I have moved it to different positions in the car and it makes little difference and situation makes no difference. What can I do to stop this noise?
  • 2 more comments
  • fretman Jul 21, 2008
    Thanks for your help but, you say grounding; the mp3 and transmitter are small, battery-powered devices not having any grounding available. Or do you mean the car radio is not grounded properly?
    Thanks for your persistence.
    Thanks. I'll try that. Thanks for taking the trouble to reply.
    Thanks again but the website address you gave me didn't work.
  • 26 Answers
This humming noise is the cause of a bad ground. try a new grounding location. The shorter the ground wire the better. Make sure the connection is metal to metal. I have had the same problem out of competition systems. Good Luck
Posted on Jul 21, 2008
  • Adam Michaels
    Adam Michaels Jul 21, 2008
    Sorry didn't realize they were battery operated it has been a long morning. If you want I can I will find you a sollution. give me about 10 min
  • Adam Michaels
    There is a website with fm transmitter solutions to problems. You might want to check it out my knowledge of technika transmitters is not very good the site is www.bdcast.webex.com. Im sorry I did not off hand but maybe this will help If this does not help I will have to research it on the web. Good Luck and let me now if it helps at all.
Can I add FM frequencies to my receiver?
Unfortunately no. Use an AUX input or a 'stand-alone' FM transmitter.
Jun 13, 2014 | Delphi SKYFi3 XM Radio Receiver
Low hum on one radio preset on Beosystem 2500
local interference find another frequency for classic fm there are lots
Jul 21, 2013 | Bang and Olufsen Audio Players & Recorders
Nad 7140 fm low frequency hum
This is probably a 60 cycle hum and the problem is more likely confined to the am/fm board, there is a bad ground due to poor solder joints, broken ground wire, an open capacitor, this may not be easy to find, but it is a start.
Apr 22, 2012 | NAD 7140 Stereo Receiver With Phono Input
I just bought the Jabra Cruiser for my car but it does not have a manual with it. what does the FM transmitter do? what is it used for? does it work like a regular built in car bluetooth where the music...
The FM transmitter feature will pick both calls and music from your phone, via bluetooth communication, and broadcast them to your car's radio, on a pre-arranged frequency. So, yes, it will act as a bult in bluetooth car system. When you press the FM button, your car kit will announce a frequency. Then, you tune in to that frequency on your car's radio.
For full details, incuding all the features and fuctions supported, please, refer to your car kit's user guide. You can download it from this location.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Aug 05, 2011 | Jabra Cruiser InCar Speakerphone Black
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
My Nuvi 750 has stopped talking, still shows the map but no voice
That has happened to me several times. When it happens I go to Tools > Settings > Language. In my case, the Voice field is empty, so I click on the Voice field and then select American English-Jill (TTS) and it's okay afterwards.
May 05, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
How to set up fm transmitter for sanyo gps nvn-4370
At the main menu press settings
press FM Transmitter
Turn transmitter on by pressing off. Will change to On
Press the Frequency button. Than change the frequency to one that doesnt have a radio station.
All sounds from the GPS will now be transmitted to the frequency set. Make sure your FM radio is set to the same frequency.
With my one vehicle this option does not work very well & is full of static because my radio entenna is at the rear of the car. The GPS only transmits a couple of feet.
Dec 27, 2008 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Technika fm in car transmitter
Tune in the transmitter to one of your car wireless stations - switch on - play MP3 player and it should work
Hope it works
Tony
Jul 11, 2008 | Pyle iPod Car Stereo FM Transmitter w/LCD...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Using my car speakers with my Garmin Nuvi 350
No, unfortunately ther is no way to get the unit to use your car speakers. To do this, the unit would have to have an FM transmitter or be able to connect to one. It does not have this capability. Sorry.
May 20, 2008 | Garmin nuvi 350 GPS Receiver
Car Audio & Video Logo
627 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
