Tape's film not being released when ejected. - Televison & Video
  • 143 Answers
I think you mean that when the tape is ejected it leaves some tape loose in the machine this is caused by failure of the take up clutch to engage on eject probable cause can be belt, or clutch mechanism
Posted on Jul 22, 2008
My VHS player will occasionally accept the vhs tape but then it pulls out the film then turns off or ejects the tapes how can i fix it
Unfortunately there is some damage to the drive mechanism of the VCR. This will need to be fixed. I can't say what is causing it, but it is clearly not pulling the tape back inside the cassette before the eject action takes place.
Mar 18, 2017 | Emerson 4-Head VCR Video Cassette Recorder...
Eject tape from panasonic AG-6810s
I don't know,but if u broke the tape then....
Jun 30, 2013 | Electronics - Others
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Canon hi-8 camcorder will not playback recordings. full battery. ejects tape during playback
It sounds like the tape isn't turning and the player thinks it's to the end of the tape and ejecting it.Perhaps when you rewind its drawing the tape up so tight the sensor thinks it's at the end.Take the tape out and see if you can turn it by hand to release the tension.There's got to be some form of release mechanism to let the tape free wheel.Once loose I'll bet it will playback just fine.
Jan 18, 2010 | Cameras
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Eject problem SOny TRV-110E
The vlatch to spring the basket (cassette holder) is easy to access on these. Many times the eject process will take place if the holder is released. After the door is removed the holder can be released by gentley raising the latch on the right side of the holder assembly. After the tape is out further checks can be made for damp drum or tension issues.
Jul 21, 2009 | Sony Handycam DCR-TRV460E Digital...
Will not release the cassette when ejected and breaks the tape.
there is a spring attached to the tape release gear that will eventuall wear out through time, also, sometimes the rubber belts wear out and throws the timing off.
That would be the first two things to check. Make sure spring is not stretched. Try testing with cover off and watch to see if the part holding the back of the tape releases.
Mar 11, 2009 | JVC Televison & Video
Tape stuck in drive
you need to get to the underside of the tape drive itself, there is usually a manual tape release mechanism built in however it usually requires the user to wind the tape off off the spools until it is fully disengaged from the spool and then to unload the tape there are usually magnetic servos and lever arms that need to be moved to release the tape itself, without being able to see the drive myself I could not begin to explain further as each manufacturer's mechanism is different, however the tape release looks like a recessed screw on the underside.
it is possible that if you manage to rewind the tape using the manual release, that reconnecting the drive may allow the drive to eject the tape using the eject button on the front panel
Sep 29, 2008 | Quantum ATL L200 DLT Tape Drive
Canon ZR-800 Mini DV Camcorder tape stuck
happened to me too.. only with a sharp vl z3. It happened to me because it was filming while the battery ran out so the film is still in the camera!!! noooo!!! dang it!
Nov 20, 2007 | Video Cameras
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
