Question about Ahead Software Nero Express 6.0 (NERO6OEM) for PC
No sound i have wiped my computer and reinstall windows xp but now i have no sound and it is saying i have no audio devices and there is no volume control which i had sound before. can yuo help.
Try to install your sound driver which will be in that CD which comes with your computer...................or download it from internet
Posted on Jul 20, 2008
  • 476 Answers
Reinstall sound device or sound manager after that reboot to save settings,update device drivers thru device manager
restart and do sp2 updates<I'm assuming your running XP
Hope this helps,please rate me thanks
  • Verne Koti Jul 23, 2008
    Authors note .........
    When the operating system was installed the drivers package were pre-installed with the softwares standard install unless installer choose a custom install.
    For some reason different things dont always get installed properly or in the correct fashion,
    ie ,
    devices not seated in place correctly can give the appearance of being connected ( RAM ),
    Hard drives not set up correctly (BIOS)(MASTER/SLAVE)
    DVD/CD drives Leads?Which ones and where???
    I could go on but I think you get the idea,,,,,,
    All Devices need the drivers to work properly,XP needs SP2.
    Hope this helps,Please rate me,Thanks
No audio device or mixer for windows xp sp3
Desktop or Laptop computer ?
XP
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you don't have a motherboard disk you will have to download the drivers
http://download.cnet.com/2000-20_4.html Tick in either the all software or windows software box
On the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume
Click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer
you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
Sep 05, 2013 | Microsoft Windows XP Professional SP3 Full...
Theres no audio sound drivers on my sound card
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check:
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer:
if you dont have a motherboard disk you will need to download the sound drivers
Update your embedded sound from Realtek to the latest AC'97 codec.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://www.boxdrivers.com
using this link you will be able select your drivers
hope this helps
Aug 02, 2011 | HP Sound Card
I had ASUS P4VP-MX motherboard. I had installed windows 7. My problen is that Audio driver is not installed. I am fagde up that i did not get audio driver from web site, pl help me
from my experience you can use windows xp audio driver as windows 7 audio driver, just install the windows xp audio driver and you will get the driver for your windows 7
Feb 24, 2011 | ASUS P4VP-MX Motherboard
Is not working at all...i cant even record my own voice but troubleshoot says that there is no prob. by the way, i've just formatted my laptop
Assuming you ave reinstalled Windows correctly follow these instructions.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 23, 2011 | Toshiba (P000257700) Microphone
I attached the G-Max 2000 speakers that were on my XP Gateway to my Windows 7 Gateway. Though the device manager says they're working properly, no sound is coming out.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 23, 2011 | Gateway GMAX 2100 Computer Speakers
THERE IS NO AUDIO SOUND IN MY MACHINE. WHAT TO DO
Check the Speaker Connections and Volume Control Settings
1 Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound. 2 Open the volume control window by clicking your "Start" button and then "All Programs." Click "Accessories," then "Entertainment," then "Volume Control." Alternatively, just click on the speaker icon that's in your System Tray. 3 Check the volume and mute settings. If any of the mute check boxes have been checked, uncheck them. If this doesn't work, read on.
Perform a System Restore If Necessary
1 If the sound has been audible from your computer's speakers and is suddenly lost, you may need to perform a System Restore. Click on the " Start" button and then "All Programs." 2 Click on "Accessories," then "System Tools," then "System Restore." 3 Complete the System Restore Wizard. If this doesn't work, read on.
Delete and Reinstall the Original Sound Drivers
1 Deleting and reinstalling your sound driver may resolve the problem. Your sound driver may have been corrupted or may be missing. The result of this is that the restore utility menu won't be available. For Windows XP, follow these steps. 2 Click on your "Start" button. Click on "Control Panel" and then "System." Next, click on "Hardware," then "Device Manager, then "Sound, Video and Game Controllers." 3 Click on a sound device named in the Device Manager, and then press the Delete key on the keyboard. Click "OK" in the window that appears. Remove all the listed sound devices i this way EXCEPT Audio Codec and Legacy Audio Drivers. 4 Restart your computer. Reinstall the deleted drivers using the Driver and Application Recovery CDs that came with your Windows XP system.
Dec 31, 2010 | Intel Computers & Internet
I can not get a sound in my computer
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 31, 2010 | Computers & Internet
Hello, I have just wiped my hard drive of Vista home, and installed windows xp, everything seemed ok except I have no sound. I have downloaded updated drivers for it,but it still says there is no Audio...
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 14, 2010 | Computers & Internet
No sound for windows xp.
Go back into your device manager. Rught click on your sound card or sound device and say uninstall. After it is uninstalled, don't close device manager. Go to very top to your your computer's name or my computer if you didn't name it. Right click and click on scan for hardware changes. Windows will find your device and reinstall in a second. This will give you cack your volume control and sound.
Mar 17, 2008 | Microsoft Windows XP Professional With...
No sound device found
check for devices in "other devices" in Device manager
Oct 22, 2007 | Computers & Internet
Ahead Software Nero Express 6.0 (NERO6OEM) for PC Logo
57 people viewed this question
Top Ahead Software Computers & Internet Experts
Martin Murray
Tony
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
