i recently reinstalled windows xp. under devise manager i have the yellow ?! flag on the "multimedia audio controller" under "other devises." i have tried to reinstall the driver by clicking on the yellow item, but that has not worked.
i have gone to gatway to download drivers , with no apparent success. i have downloaded and run conexant_audio_6.10.14.0565 aida32 but, frankly, do not know what the results mean.
this seems to be a common problem after reinstall.
does anyone have a solution for the computer lay person?
you need to install a compatible multimdia controller/driver for your system.Uninstall the previous driver and Check out this site below for some audio drivers.Make sure it is XP compliant.
search for and Use (PCwizard) to detect all drivers on your computer write down name and number of sound driver type name number in search bar plus drivers you should find the one you need Plus did you install motherboard drivers as sometimes other drivers will not work until you do
Was this solution helpful? Show your Appreciation by rating it:
the problem is i'm using windows xp service pack 2, i got the automatic updates, but i updated to service pack 3. after that whenever i switch on the windows media player or winamp the message giving is no device found. is there any solution.
