Hoover AL130 Front Load Washer
Problem for Hoover AL130 Front Load Washer
Not heating cold water
By leighhoward8 on Jul 20, 2008
WHEN THE MACHINE IS PUT ON A HOT WASH IT IS NOT HEATING THE WATER.IT IS WASHING EVERYTHING COLD.
Best Solution
posted on Jul 21, 2008
Very Helpful)
gittos73
Rank: Guru
Rating: 87%, 301 votes
this could be 2 possible symptoms 1 the thermostat which gets the heater element to work. 2 it is the heating element that is faulty if the element has gone then this is about £15 to buy which u get both thermostats which u might has well replace both at the same time now if its the heater element then this will be around £20-25 to replace now my best suggestion is call out an engineer that doesnt charge any call out fee this will tell u exactly which if these it is if its thermostat then do it yourself easy job which will only take u around 30 minutes to do from start to finish if its the heater element then get them to do it which should cost around £65 to do this is because it needs to be sealed properly otherwise it will leak and cause more problems in the long run
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hoover AL130 Front Load Washer
Questions and Unsolved Problems for Hoover AL130 Front Load Washer
Do you recommend Hoover AL130 Front Load Washer?
Answer
Answer
My hoover wdm 150 washer dryer will not dry. The drum spins as normal but no heat is generated. The... (More)
Answer
hoover al 130 sticks on the cycle it starts on.
Answer
My hoover 6 express washer dryer has just started leaking from undearneath near the lint trap out... (More)
Answer
error 2 has being cumming up on the screen some times but now it gets to the welcome screen and no... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
