Hi, I have this ups as well, My personal adjustment with this ups, is I have installed 6 external Ags Number 120, 15 plates per battery, in pairs. And its working fine on my end , and yes ups is able to charge them all without over charging or any other problems. My ups Already has 6 internal batteries bank installed, attaching these external batteries has increased the backup time.
Thank You.
Thank You.
SOURCE: mge pulsar 3000 does not power up
MGE Pulsar 3000 is an online UPS. try to check the battery first if its ok. coz for an online UPS it will need to have a good working UPS battery to trigger the switching relays to on the online UPS unlike backups UPS that can be turn on without any batteries
SOURCE: What software do I need to connect to my MGE UPS
The Personal Power Pack (UPS_psp_2_60_02.exe)is the best for MGE UPS,but it has been discontinued for a long time and it runs only on XP and older windows os.
For adjusting the advanced parameters of the UPS,u can use the upsdrv15.exe. This software works only with serial connection.
The only solution for Windows 7 is Eaton's Lan Safe software (since Eaton bought a part of MGE,the UPS is recognised by their software).
These software are not very easy to find,but they're there.
SOURCE: Please can you tel
Specifications for MGE Pulsar Extreme 1500 C 2U Rack Battery kit
Voltage
12V (Per Cell)
Capacity
6Ah (24W)
Weight
8Kg
Dimensions
151mm x 94mm x 51mm (Per Cell)
Lifespan
3 - 5 years
Type
Sealed Lead acid battery rechargeable highly efficient, leak proof and maintenance free
I think there are four batteries in the pack.
