Unsupported cartridges on lexmark x4580 - Office Equipment & Supplies
  • Anonymous Jul 21, 2008
    lexmarkx4580 printer new brand new cartridges display on computer showsunsuported cartridges on printer shows wrong cartridge left wrong left tried swopping wont workt
  • richard350 Aug 18, 2008
    Brand new cartidges...genuine Lexmark at £40 per pair and I get the message "Incorrect cartridge". Tried everything to reset but no avail.
As a temp solution I put some saliva on the pcb on the cartridge. Strange I know but it worked for me !
Posted on Oct 30, 2009
I got the same problem on a Lexmark T630. I will print 3 pages and stop and gives this message. I changed the chip and it works ok. I the cartridge has a chip, change it and see.
Posted on Jul 21, 2008
  • 23 Answers
SOURCE: how to reset lexmark x4580 ink cartridge after refill.please help
http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
Page 99-100
Posted on Sep 27, 2009
guide2u
  • 461 Answers
SOURCE: "unsupported cartridge"lexmark X2470
reinstall the cartridge. Turn of the printer leave it for 10 minutes and restart again. If you still have more problem check below link, youmight find some useful info.
http://pc-and-peripheral.blogspot.com/
Posted on Oct 19, 2009
  • 224 Answers
SOURCE: Will the lexmark x4580 work in black and white
Yes it will work in black and white.
You can also change the settings and keep only black and white if you want to save the color cartridge.
Its available in Printer settings--Options--Black&White.
Posted on Nov 06, 2009
  • 320 Answers
SOURCE: Error 32 Unsupport Print Cartridge Lexmark T630
on the inside of the top cover on the left side when the door is open there is a little switch youll see a little metal tab 5/16'wide push on this and see if the error clears. if it does this can be adjusted. if not pull the cartride out there are two sensors on the right inside one close to the front this is an optical sensor blow this out with canned air if you dont have an air compressor. then further back inside there is a two pin sensor make sure that if you push in on these that they dont stick. next there is a smart chip on toner caartridge that lines up with those pins when its installed clean these contacts. doing all of these things usually geets rid of the problem. no parts have been replaced recently right? check the connector to the logic board this is theeonly 3 pin connector that has black and white wires. this sohlud fix your problem
Posted on Nov 28, 2009
  • 22 Answers
SOURCE: i have a Lexmark Printer z2400. i have a lexmark
that can be happened with some problem of cartridge or cartridge holder.
if you can check the printer with your older empty cartridge, and you can see
the different error message with that , it says your printer is OK.
and have some problem with your cartridge.and need to replace it.
if you can see same message with your old and empty cartridge,
you can clean both of cartridge the connecting pads ( in printer cartridge holder and
back side of the cartridge ) using by IPA and check again.
if had corrosion or some ink swallowed problem , can be clean with that.
after that if you got same result, you need to check your cartridge with
another printer or your printer with another good cartridge.
Posted on Jan 03, 2011
Testimonial: "I put in the older empty cartridge, and the error message stopped. At least I'm only out of the price of a new black cartridge and not a new printer."
How do I configure the lexmark x4580 to identify my computer?
Try to insert the installation disc into the computer hard drive and run the install setup. Simply follow the instructions on your computer screen.
You can also try the downloadable Lexmark X4580 printer driver from the Lexmark website at http://bit.ly/pOdfTQ. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Jul 12, 2011 | Lexmark X4580 InkJet Printer
I have an lexmark all in printer and i just recently brought refill ink and when i install them it keep telling me unsupported cartridge please help
Though Lexmark does not recommend using refilled ink cartridges, you may try to refer to this article in the Lexmark website on Unsupported Cartridge Error on a Lexmark X3330/X3350 All-In-One to determine and resolve the problem. If error continues, try to insert a different known working cartridge. Thanks.
Feb 15, 2011 | Lexmark OfficeCenter X3350 All-in-One...
Replaced cartridge,get unsupported cartridge message,lexmark2500
I have a lexmark X2470 all-in one printer.I am getting the messarge reading"unsupported cartridge" It is a 3rd party refill.
Jun 07, 2010 | Lexmark X2500 All-In-One Printer
If this is a genuine Lexmark device and a genuine Lexmark cartridge and you followed all the install instructions, return it to where you bought it for a replacement. If you get grief there, contact Lexmark directly. Please have your receipt available when you take these actions.
thanks for your interest in FixYa.com
Jan 20, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Will the lexmark x4580 work in black and white when the colour cartridge is empty?
Nov 06, 2009 | Lexmark X4580 InkJet Printer
Ink cartidge
If you have new, correct (for your printer) cartridges, it sounds like they are bad. Take them back to where you bought them or contact the Lexmark Technical Support Center (TSC).
For TSC, go here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0 and type in X4580 in the SEARCH BY MODEL box. You now can see options to call, email, or chat with Lexmark.
Steve
Feb 17, 2009 | Lexmark X5470 All-In-One InkJet Printer
How to reset lexmark x4580 ink cartridge after refill.please help
Page 99-100
Jan 15, 2009 | Lexmark X4580 InkJet Printer
Lexmart x4580 all in one printer
Hi I have a Lexmark x4580 all in one WI FI dos not connect to my netgear it finds it and I put in all the right passwords just will not connect
Dec 04, 2007 | Lexmark X8350 All-In-One InkJet Printer
Unsupported cartridge error
Unload and reload the Lexmark software........AND clean the printer contacts,
not neccessarily the cartridge contacts.........
that outta do it.
Sep 05, 2007 | Lexmark X2470 All-In-One InkJet Printer
599 people viewed this question
jasbo
jasbo
