Question about Ricoh Aficio 450 Copier
Developer.... hi.... how can i check my developer in afficio 450 ... wat will be the sign that my developer is olridy overuse or need to be change.... tenkz in advance cuz i just purchase a surplus afficio 450...
    Problem Solver:
  • 19 Answers
Change developer every 300,000 copies
Total copies divided by 300,000
PM 150,000 copies. Items to be replaced. Drum, Drum blade, Charge Roller, Charge roller cleaning pad, drum pick off pawls, paper feed roller, Transfer belt and transfer belt cleaning blade, fuser heat roller and pressure roller, Doc Feeder transport Belt,
Hope this helps
Posted on Dec 24, 2008
    Sergeant:
  • 329 Answers
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Posted on Jul 22, 2008
Afficio 450 developer type 4 or type 5
This machine takes Part Number "887733: Developer Type 5"
Hope this helps.
Jul 05, 2009 | Ricoh Office Equipment & Supplies
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
Wat is da problem of my copier afficio 450
Thraser, your still battling this machine? Of course your readings will be off if you only have developer coverage over half the mag roller? That's where I would start.
I also now wonder about your model #, because I don't think that the 450 has a VSDP reading, but the newer ones do. It refers to the "immediate post-pattern output" of the ID sensor -not surprised that these readings would be whacked!
Mar 05, 2009 | Ricoh Aficio 450 Copier
Afficio 450 is der a sensor in toner supply
Do you know how to calibrate the toner/developer sensor?
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Changing developer in afficio 450
Preform SP 2-801 then 2-805.That will do it!
Jan 21, 2009 | Office Equipment & Supplies
Change the developer in afficio 450
To remove the Dev. unit.
1. Open the right upper cover and front cover.
2. PCU. (☛ 3.11.1)
NOTE: Spread paper on a clean flat surface that is free of pins, paper clips,
staples, screws or any other metal objects.
3. Loosen [A] (! x1)
4. Rotate bracket [B] left.
5. Development unit [C]
NOTE: Pull slowly to avoid scratching or nicking the development roller.
6. Set the development unit on the spread paper.
7. If you are temporarily installing a used development unit for test purposes,
perform SP2-220 and 2-802-1 after installation (☛ Chapter 5, “Service Tables)
Replacing the Dev. material.
1. Development unit (☛ 3.12.1)
2. Remove the development roller (☛ 3.12.3)
3. Empty toner [A]
4. Turn drive gear [B] to ensure that no developer remains in the unit or on the
developer roller.
NOTE: Dispose of the used developer in accordance with local regulations.
Work carefully to avoid scratching or nicking the development roller.
5. Pour approximately 1/3 of the developer [C] evenly along the length of the
development unit.
6. Rotate the drive gear [D] to work the developer into the unit. Repeat [C] and [D]
until all toner is in the unit and level with the edges.
7. Reassemble the development unit
8. Cover the toner entrance hole [A] with a piece of paper.
9. Install the development unit in the machine.
10. Turn on the main power switch, make sure that the machine has warmed up,
then perform the TD sensor initial setting using SP 2-801.
NOTE: When performing this setting, cover the toner entrance hole with a
piece of paper. This prevents used toner falling from the PCU into the
development unit during the TD sensor initial setting and interfering
with the Vref setting (toner density reference voltage).
11. After performing the TD sensor initial setting, remove the sheet [A] from the development unit.
This is how you replace and reset (calibrate) the new Dev. material.
Jan 20, 2009 | Office Equipment & Supplies
The copy of afficio 450 become lighter
You may want to consider putting developer into the unit. What is the copy count on the machine?
Jan 15, 2009 | Ricoh Aficio 450 Copier
Afficio 450 seeting
Auto setting. If you are getting light copies, you might need the developer replaced as well.
Aug 21, 2008 | Office Equipment & Supplies
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
294 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
