Question about Smeg Microwave Ovens
No power, is there a fuse for model no. SA31-1MX
  • Smeg Master
  • 9,042 Answers
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
It will probably be a grey or white ceramic fuse. If you can't find one locally, try Smeg Service spares.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
No power
Your stove should be on its own breaker or have its own fuse. Some models of stoves have fuses within their own control panels too. Check your home's panel to see if a breaker has been flipped or a fuse blown, and follow up with the owners manual for your make and model of stove.
Mar 05, 2014 | Magic Chef Microwave Ovens
No power
i had the same problem and did what this fella suggested and worked just fine. There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 4 in the parts listing (part number STD384200).
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
Feb 06, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
Where is the fuse located on the sharp r-1875 microwave
you have to take off the external housing and you will see a glass fuse near the power source.
Jul 19, 2011 | Sharp R-1874 Convection/Microwave Oven
While cooking it just quit. Checked circuit breaker & was ok. I have no schematic of the inside so I haven't taken apart yet to see if there may be an inside fuse.
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Or, on a line filter control power. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. Since you provided no model number, I can only give this basic advice.
If you have any questions, or need additional assistance troubleshooting, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Aug 12, 2010 | Kenmore Microwave Ovens
This model just stopped working while heating food up. Now cannot get even the power to register when you plug it in. Is this doen for?
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
Jul 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Maytag 2 yrs old. Completely dead - like getting
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this wiring diagram at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
This model has TWO potential causes. The line fuse or the Thermal Cut-Out (Thermostat) for the Magnetron. The line fuse is connected in line with the power cord inside the unit and is listed as part of item 26 under the "Cabinet-Base-Cavity" heading.
The Magnetron Thermostat is listed as item 6 (part number 56001028) under the same heading. If you managed to overheat the oven any time recently, you may want to check the thermostat to see if it is still good. It should read 0 ohms when measured out of the circuit across the terminals.
May 24, 2010 | Maytag MMC5000 Microwave Oven
Is there a fuse or breaker inside this model.
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
The line fuse is listed as item 12 (part number 56001353). Keep in mind, there are different vairations on the model number you provided. You need to look at the model number you have and include the last three letters as well. I reviewed most of these models and they appear to all have the same parts. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended. If you wish to order on line, use the part numbers to search by comparison as the model number you listed this question under may not be available at all the websites I have provided. The parts, however, ARE listed.
May 13, 2010 | Amana AMV5164 Microwave Oven
It just quit while cooking. Is there afuse in this microwave?
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
The line fuse is listed as item 12.
Apr 27, 2010 | Maytag MMV1153A Microwave Oven
GE model JE2160BF03 no power. Blown fuse.
They are put out when something metal is put inside and cooked for a few min. They are also put out with power surge. It protects your mag tube. Plus they just go bad sometimes. Could be a number of reasons but these are the most common.
Nov 17, 2009 | GE Microwave Ovens
Not working model # jvm1339bw 002
Check the main internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Jan 30, 2008 | GE JVM1340AW/BW/WW Microwave Oven
Microwave Ovens Logo
265 people viewed this question
Top Smeg Microwave Ovens Experts
William Miller
William Miller
Chris Hall
Chris Hall
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
