Question about Canon PIXMA iP4000 InkJet Photo Printer
The computer doesn't detect my printer
Evrytime when i turn on my printer with the USB attached to my cmptr, the computer will popped up the sign "USB does not recgonize". I've done many things like turn the printer off then on back, check the USB cable and restart my computer but still it doesn't work. So what's wrong wth my printer.
  • Anonymous Aug 05, 2008
    Yes, my iP4000 was working well.  Then I packed it up and moved house.  When I unpacked it, my computer (a mac) wouldn't detect it.  IT powers up, but its invisible to my computer.  I tried it on a windows machine too.  Nuthin.
    Grrr.  Reinstalled drivers on both machines, tried new cables, nothing.  Powers up, lights light, but nuthing.
    Novelist:
  • 158 Answers
On your Windows desktop, left click mouse on START. Left click on CONTROL PANEL, AND LEFT CLICK ON THE PRINTER ICON. On the printer window, lft click on ADD A PRINTER. Choose ADD A LOCAL PRINTER, and click NEXT. On CHOOSE A PRINTER PORT window, click on LOCAL PORT, and from the drop down menu, choose a USB virtual port. Now your computer should see the printer.
Posted on Aug 05, 2008
Computer won't detect printer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X1290 All-In-One InkJet Printer
The external hard drive isn't being read from the computer. Sometimes, the hardware will light up and sometimes it doesn't. The computer is not able to detect the hard drive. Please advise.
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
May 29, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I've lost my CD to install the printer to my laptop. What can I do?
Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
Turn the computer on and wait for it to boot up.
Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
Turn the printer on.
Click on "Start menu" and go to the "Control panel".
Find "Printers and hardware" box and click on it.
Take mouse and click "Add printer".
When you see "Welcome to the add printer wizard," hit "Next."
Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install printer manually. Click "Next."
Select printer port. Use the recommended port for best set up options. Click "Next."
Pick manufacturer and printer. Click "Next."
Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
Print a test page to be sure printer is set up and online. Click "Next."
Receive a successful completion of installation of printer message. Click "Finish."
Feb 16, 2011 | HP Photosmart 4180 All-in-One Printer
I can't do video chat with anyone because the internet cannot detect my web cam, and i can take picture with it because it never turns on, and when my PC is put to sleep when i try to turn back on it...
Hi
Very simple
Simply first restart your PC and then connect the webcam.
If the message comes again follow this
Right click on My computer-> select manage option -> a window will pop uo select device manager -> in device manager right window select USB and expand the plus sign -> you will see hare all the USB in your computer
Select the USB which is showing yellow in colour and ricght click on that -> select unistall
after that select the main USB option and right click on that and select the option scan for hardware changes
Your PC will eb able to recognise the webcam.
Jan 16, 2011 | Computers & Internet
How to install (assemblw) hp d2668
hi
  • Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
  • Step 2 Turn the computer on and wait for it to boot up.
  • Step 3 Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
  • Step 4 Turn the printer on.
  • Step 5 Click on "Start menu" and go to the "Control panel".
  • Step 6 Find "Printers and hardware" box and click on it.
  • Step 7 Take mouse and click "Add printer".
  • Step 8 When you see "Welcome to the add printer wizard," hit "Next."
  • Step 9 Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
  • Step 10 Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
  • Step 11 Select printer port. Use the recommended port for best set up options. Click "Next."
  • Step 12 Pick manufacturer and printer. Click "Next."
  • Step 13 Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
  • Step 14 Print a test page to be sure printer is set up and online. Click "Next."
  • Step 15 Receive a successful completion of installation of printer message. Click "Finish."
  • Jul 12, 2010 | HP Office Equipment & Supplies
    How can I install HP Officejet 6310 All in one printer without an installation disk?
    you cant install printer device without the driver disk. you can connct the printer to your computer but your computer wont recognize the printer. please click this link for your printer driver.
    Apr 04, 2010 | HP OfficeJet 6310 All-in-One Printer...
    My computer is unable to detect this printer when I connect it. What could be the problem? The printer also does not turn off when I press the power button sometimes.
    If the printer is not being detected correctly check both ends of the USB cable to ensure they are firmly attached. Do not have the cable connected to a USB hub or other device. If possible, try using an alternate USB cable that has been tested with another device and is known to work correctly. Ensure the USB cable is connected to a port on the BACK of the computer if possible as some ports on the front of the computer do not neccessarily supply the amount of power that is needed for printers.
    Check the Device Manager listing to ensure the printer is showing up. To do this power the printer on and right click the My Computer icon on your computer then left click Properties. Select the Hardware tab and click the Device Manager button. Are there any listings displayed with a question mark or exclamation mark? Is USB Printing Support listed under the Universal Serial Bus Controllers section? You may need to click the plus sign beside this listing to expand the category tree.
    If the printer is listed with an exclamation mark or question mark, right click the printer and click Remove, then select Action from the top of the window and select Scan For Hardware Changes. This should 'find' the printer again and the drivers should be reloaded successfully.
    If the printer is listed correctly, try selecting the printer properties (browse to the printer window, right click the printer and select Printing Preferences) and clickc the Ports tab. Ensure the port that is selected is USBPRN01.
    I hope this helps!
    Feb 03, 2010 | HP PSC 1510 All-In-One InkJet Printer
    HP Solution Center No HP Devices Detected
    Try this
    1.Right click on MY computer ->Properties->Hardware->Device manager.
    2.You will get Device manager window popping out.
    3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
    4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
    5.Disconnect the USB and reboot the PC.
    6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
    Thanks
    Riz
    Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
    My hp deskjet D2500 was given to me in a warranty exchange 3 days ago. I have bought a usb cable for it and everything hooks up well, although when i go to use it a box pops up on the computer saying...
    Check and make sure your printer is defined in the printer setup, and is selected as the default printer.
    Alternately you can download the printer drivers at
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3571291&lc=en&cc=us&dlc=en&lang=en&cc=us
    and re-install the printer. From the computer being off, make sure the printer is on, and USB cable attached, then turn the computer on. The OS should detect the printer on boot, and automatically install the drivers, or you can install them manually from the downloaded drivers referred to above.
    Nov 19, 2008 | HP Office Equipment & Supplies
    Canon PIXMA iP4000 InkJet Photo Printer Logo
    62 people viewed this question
    old marine
    old marine
