FixYa.com
Tags:
Refrigerators
Generic problem for all Refrigerators
I have a kelvenator 2
posted by aking37 on Jul 20, 2008
I have a kelvenator 2 door glass refrigerator that is not keeping tempurature it has 2 fans on the evaporator.
I had a company in to look at it and they took out the old gas and charged it with the proper amount.
The technician said because it has a capillary tube that the charge has to be exact.He tok out 1lb 6ozs and the system takes 14ozs.
It worked ok for a day then got warm the coil is frozen the fans are running but no air flow ?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 21, 2008
Helpful (85)
22yooper
Rank:Guru Guru
Rating: 85%, 391 votes
Evaporator temperature is what controls on and off operation and indirectly controls the case temperature. The charge in these system does have to be correct to the ounce. To much charge and the evaporator Pressure will run end giving a higher temperature. To little charge and it will only frost part of the evaporator. These system are critically charged systems.
These type of systems are controlled by the thermostat which should cycle off at a preset temperature and not return to the on position until the cooling coil reaches 37-38 degrees. Setting the control to cold will cause the evaporator to freeze up. Turning the temperature control to the off position will allow the fans to melt the ice from the coil. When reseting the control set it to #1 or 2 setting to begin with.
Also an old unit with an old compressor may not allow the unit to reach design temperature before freezing up the coil.
Rating Locked! (?) aking37 has rated this solution as Helpful
This Problem Also Relates To: GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black GE Profile PSS26NGS Side by Side Refrigerator GE GSS20IEM Side by Side Refrigerator Bosch KSR34464 Refrigerator Haier HSB03 Compact Refrigerator Haier (492420265334) Refrigerator With Ice Box Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Can you Help with these Refrigerators problems?
Refrigerators
neenpartlook
neenpartlook Answer This...
Refrigerators
not freezing properly
not freezing properly Answer This...
Danby DWC283BLS Wine Cooler
E7 Code
My danby wine cooler keeps... Answer This...
Refrigerators
i havev a servis fridge
i havev a servis fridge freezer... Answer This...
Refrigerators
Hi, my integrated fridge is
Hi, my integrated fridge is no... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
