Question about HP Color LaserJet 2600n Printer
Safety power fuse location HP 2600n
Where is the power fuse located on the HP 2600. There was a power surge and need to locate fuse.
  • TW66 Jul 21, 2008
    Thanks for the help.
  • 81 Answers
Power supply board. you can trace it near where you can see the power cord
Posted on Jul 21, 2008
Where is the fuser located
It is located in the top of the machine near the exit. There is a very good video on youtube which shows how to replace the maintenance kit which includes the fuser. The fuser part starts at about 3.5 min into the video. I googled HP Color LaserJet 2600n Printer Where is the fuser located and it was the first video listed. I hope this helps.
Dec 12, 2013 | HP Color LaserJet 2600n Printer
Hp 2600 55.1
55.1 is a DC Controller error.
Power down for 30 seconds. Make sure printer is plugged directly into the wall outlet, not a surge protector. Power on, if error returns, go out the www.hp.com/support
Answer the questions and download the new firmware if the printer isn't at that level.
If it is replace the DC Controller
Oct 28, 2011 | HP Color LaserJet 2600n Printer
Hp lazer jet 2600N won't print red color what will fix it. Has a new cartridge
You may need to replace FORMATTER BOARD & DC CONTROLER BOARD ASSY which are located behind the printer. Both BOARDs are side by side together. Just open the back cover, you will see it.
Jun 10, 2010 | HP Color LaserJet 2600n Printer
Ihave hp 2600n printer error 55.1 & i turn it off and open with out soved pls help me thank
DescriptionDC controller error. The device has experienced an internal hardware error. Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information. 55.xx PRINTER ERROR alternates with CYCLE POWER TO CONTINUE An internal communications error occurred. The page containing the error will automatically be reprinted. 1. Check the power at the customer’s location. 2. Replace the formatter and/or firmware DIMM. 4. Replace the engine controller board. 5. Replace the formatter board. On the 5si, 8000, 8100 this could be a fuser problem. Try replacing the fuser.
Apr 11, 2010 | HP Color LaserJet 2600n Printer
My 2600 laser printer have 55.1 error message its not working.
Turn printer off for 60 seconds. If it's plugged into a surge protector, plug the printer into a wall outlet. Power it on. If it works - good. If not check the firmware version and upgrade it if needed. Other wise replace the DC Controller.
Jan 11, 2010 | HP Color LaserJet 2600n Printer
HP Color laserjet 2600 only black print is commong
It a problem with printer fusing assembly. so you can checked it from service center.
Nov 23, 2009 | HP Color LaserJet 2600n Printer
HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Oct 05, 2009 | HP Color LaserJet 2600n Printer
Hp 2600 thermostat, what is it?
It should be a round "can" looking device that the wire connects to. It will be touching the fuser roller.
Aug 21, 2009 | HP Color LaserJet 2600n Printer
Bose lifestyle 25 not coming on
There is probably a fuse located somewhere on it and the surge would have blown it, I know that most larger speakers and amps have safety fuses so they do not blow apart, the same goes for most electronics nowadays..find the fuse fix the problem. thanks Steve
Jun 13, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
HP Color LaserJet 2600n Printer Logo
423 people viewed this question
Seeker5211
Seeker5211
