Question about Hotpoint Ultima WF860 Front Load Washer
Wf860 about to explode!
My WF860 has developed a nasty vibration on the spin cycle, joined with a horrendous noise like it's about to explode! Whipped the lid off to discover the three chunky bolts that hold the concrete block to the drum 'loose'. However, these bolts can't be tightened up anymore, suggesting they are fully home. Having removed the bolts and then block, I can see the three supports are badly worn (presumably where the concrete block has been rubbing against them, working all the more loose, excerbating the issue). Question is, does anyone have, or could take, a photo of the top of their drum, less the block so I can evaluate the damage caused. Unless I can get this block fixed tightly to the drum, looks like I'll be forking out for a new machine!
  • jaspinall Jul 20, 2008
    So yes, asking a dumb question this morning regarding some other owners whip their machine apart to take a photo! lol...
    Any ways, I figured the next course of action would be to either pad the bolts out with thick washers (circa 6mm) or cut some of the bolt off with a junior hacksaw. The latter solution prevailed, fixing the counterweight securely against the tub. However, as I tightened one of the bolts up, the actual support snapped cleanly off, leaving the weight secured in place by just two bolts!
    I set the machine off performing the rinse/spin cycle it missed this morning, starting off quite well, no noise or excessive vibration at all. Until of course, it got to the 1600rpm spin, where of course, it sounded like it wanted to take off again - the noise was incredible.
    Figuring a new machine is basically in order, I pulled the washing out then dropped the machine out the back garden on it's side so I could take a look at the underside of the machine. The two shock absorbers look intact, no obvious signs of wear. However, the smaller concrete counterweight bolted to the front of the tub was also loose! Couldn't believe my eyes! Both weights loose. Given there is no immediate access to the front of this weight to then tighten up these bolts (assuming they'd also need cutting down) it's safe to say this machine has spun it's last spin cycle, lasting exactly 3.5 years!
    Thanks for the suggestion above.
  • Anonymous Jul 25, 2008
    the thing keeps shaking itself apart.. we are on our second drum, second set of bearings. the concrete weights have been reattached and now the thing is locked with all our holiday clothes inside.
  • 1,462 Answers
There is no magic to the counterweight supports. if they are damaged, you will have to replace the tub and it is not a worthwhile repair. it is quite a common problem
Posted on Jul 20, 2008
In the spin cycle it makes a loud banging noise and vibrates uncontrollably. when u raise the lid it stops spinning right away. is it worth it to fix this or replace it?
You may have to lift the lid and rebalance the wet clothes inside
make sure that the machine is level and the bowl supports or in good condition as an off level bowl will go to unbalance on start of spin
Apr 13, 2015 | Washing Machines
Kenmore 80 series spin cycle isn't spining water out
could be defective part or lid switch problem
Dec 10, 2013 | Kenmore Washing Machines
My dryer vibrates loudly, wondering if it is a bearing problem, and if so, is it worth getting fixed?
vibrations and such noises are definitely caused by something out of balance, or not spinning truly. some maytags were plagued with wimpy blower wheels which when worn made horrendous noises. without a complete model number i am at a loss as to where to point you though.
enjoy, have fun.
Aug 03, 2010 | Dryers
When in the spin cycle it now makes a horrendous noise
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
May 14, 2010 | GE WPXH214A Front Load Washer
Vibration of wash machine
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
May 22, 2009 | Danby Washing Machines
VERY noisy spin cycle wf860
it sounds like your concrete block is loose. unplug machine and remove lid check block on top of drum there is also 1 at the front of the machine below the door seal. WARNING DO NOT OVERTIGHTEN THE BOLTS.
Mar 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Spin Cycle Problems / Noise
Have notice some spring below or in the floor ? the drum basket need a balancer spring in order the drum will control it movement and soundless .available in any apliances center.
Jan 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
250 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
