Sony combi dvd / video player . 4 years old. tapes not playing and when ejected the tape is caught up in the machine.
    Habit-Forming:
  • 166 Answers
The usual problem with these machine is the take up clutch situated in the middle of the reels and underneath. The nylon gears split in the centre causing the outer to jam it really is a job for a technician.
Posted on Jul 22, 2008
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
Go-Video VCR Problem with accepting/ejecting tapes
As with any VCR, there are rubber parts inside that have become slick. This is a simple repair for any shop. The mechanisms are Samsung ones if I remember correctly. Expect a parts cost between $20-$40. Add in the local labor rate for the total cost. This is worth the repair cost as any replacement would not last anywhere near as long. This is also a normal occurrance as rubber parts harden with age. I have repaired many of these over the years.
Dan
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Sep 28, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Tape Problem
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Jun 27, 2008 | Mitsubishi HS-U776 VCR
Lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Feb 21, 2008 | LG V181 DVD Player/VCR
Video tape problem
get a dvd player u cheap skate
Feb 18, 2008 | LG XBR446 DVD Recorder/VCR
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
