Question about Hotpoint FFA90 Bottom Freezer Refrigerator
Ice Build up and leakage of water
Hi there, thanks for your advise on how to hopefully rectify my problem. The problem I have now is how do I get the panel at the back inside the freezer off. It appears to need an allen key, but the holes are a star shape. Sorry to be a pest but I am on my own and so need idiot proof instructions!!
  • 89 Answers
What is the model number? Also, you can buy a set of "star" screw drivers at your local hardware store "autozone" for under 10 bucks. And, intructions for fixing your problem can be seen at:
http://www.houstongofarappliancerepair.com/Refrigerator.html
Goodluck, Brian
Posted on Jul 21, 2008
Have a second hand Homemaker chest freezer model hmbd155....recently noticed fluid around the floor....? Leaking..don't have a manual and noticed a dial on the bottom left hand corner .What this do..?
The dial Adjusts the temperature. If it is adjusted too cold you might have ice build up underneath the freezer thus causing the fluid that you see. As the freezer is old it can also be that the insulation underneath is a bit old causing the ice build up and fluid leakage. A broken thermostat (dial) will also cause too low temperature inside and possible ice build/fluid leakage.
Oct 04, 2017 | Refrigerators
Sears ice maker
Does the motor makes a noise when you try to get ice?
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water is collecting and freezing on the bottom freezer.. Overflow water is leaking on to floor,
bad door seal resulting in condensation and water leakage. secondly a bad defrost terminator will cause a build up of ice in freezer
Mar 12, 2015 | Whirlpool Refrigerators
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Hi, I have a Whirlpool refridge. The ice maker is making ice, yet the ice is not dropping into the ice bucket. If you put ice into the ice bucket it will correctly drop through the door. The ice seems...
Hi and welcome to FixYa. I am Kelly
Often ice maker issues are a symptom of an automatic defrosting problem OR a leaking (dripping / bypassing) ice maker water valve.
First off you should try and prove that there are no un-necessary water leakages by doing the following:
1. Turn the icemaker OFF
2. Remove the plastic line where it connects to the thru the cabinet water tube by pinching the clamp and pulling down on the plastic tube.
3. Place end of the plastic tube into a bucket for about 12 hours. At the end of 12 hours check the bucket for ANY water. If there is a noticable amount of water (more than 1 oz) the water valve is leaking water by the valve diaphram seat. The only remedy for this is to change the units water valve assy.
As far as a possible automatic defrosting problem..... soft ice cream is a symptom along with that of low ice production.
The evaporator coils get a substantial amount of ice build up on them and then the airflow in the freezer compartment is restricted resulting in a change in the freezer comprtment temp. If you do have an automatic defrosting problem you will soon notice noise from the evaporator fan as the ice build up encroaches into the fan blade path. Additionally the fresh food compartment will warm up.
The ice maker will not cycle until it reaches 16 to 15 deg F. The ice maker harvest cycle is started when the ice maker thermostat closes and advances the ice maker module.
Do the water in the bucket test and then look for signs of ice build up on the evaporator coils.
If neither of the above manifest / present then download this manual and follow the troubleshooting procedures:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Thanks for choosing FixYa.
Kelly
Sep 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker problem with Samsung RB215BssB refrigerator
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it can freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Refrigerators
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Leaking Fridge
defrost system may not be working - this is quite difficult to diagnose
doug
Jul 25, 2008 | Refrigerators
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
67 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
