Sky upstairs I have a sky box downstairs but would like to also have sky upstairs without paying for another sky box, Is this possible or would it be best to just get a freeview box?
    Scholar:
  • 143 Answers
Yes on the back of the box there is a RF2 output...
run a coaxil aerial cable from there to your required TV, you then need to tune the 2nd tv to the sky box.
You can also buy a 'Magic Eye' and a 'extra remote' this will allow you to change channels from the second destination with only 1 digi box.
Down point is that you have to watch the same channel on both tv's.
a second card and box and a dual LNB will allow you to watch seperate channels.
Posted on Jul 21, 2008
I have just got a sky+hd 2tb box installed, i have a wireless transmitter and sender that i use to watch sky upstairs in my bedroom, i can get sky upstairs through the wireless scart connector/video sender...
You need to find out if you remote is infrared or radio frequency. If infrared then there are remote extender devices that you can purchase to use your remote. If it is RF, then your search would be the RF remote extender box.
Jul 02, 2014 | Computers & Internet
2nd tv will not find signal after electric power cut
usually a surge like that can damage the circuitry
Jul 21, 2012 | Televison & Video
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Hi, i have just bought a logik wireless av sender so send my sky signal to the tv in the bedroom. the instructions in the manual are very basic and i cant get it to work. any ideas. on the tv in the...
Red and white are only Audio ports.
IF there is a scart port plug your av receiver into the scart. Take note on which number your on ie channel there should be several numbers you can choose on your tx/rx then go down stairs to your sky box and ensuring that you are on the same number as the one upstairs.
Then just plug it into the back of your sky Box.. the number on your sender are incase your getting interfearance from other sources in the home. have a play with this and see what works best
Hope this Helps
Little Dish Fitter
Aug 22, 2009 | Televison & Video
Sky box saying no sattelite signals
Check the coax connector and the cable, try anoter cable if you have one available.
Good Luck.
Feb 18, 2009 | E-Machines eMachines Desktop PC
Bush btv180t- connections
Hi ,
Thanx for the reply.
managed to sort it second time around.
Just ran the coax from the rf socket downstairs to the back of the tv link ,which is attatched into the ariel socket in the back of upstairs tv.
the tv link comes with good instructions,but need reading carefully first.
Jan 14, 2009 | Televison & Video
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Televison & Video Logo
347 people viewed this question
Top Televison & Video Experts
Electro Med Services...
