Question about AEG 18 in. Favorit 54750Vi Slim-Line Built-in Dishwasher
Door latch in closed position
The latch is in the closed position despite the door being open. How do i reset the latch into the open position?
    President:
  • 1,462 Answers
Put two small screwdrivers in each side of the latch and lever upwards (best way) or otherwise take the door outer panel and fascia off so you can get at them
to stop it reoccuring, bend u catch on cabinet slightly downwards
Posted on Jul 20, 2008
My dishwasher runs but door is in locked position. it will now run with door open and the door wont close/lock
It sounds like your door latch got tripped into the closed position (even though your door is open). You MIGHT be able to use a screwdriver or some tool to be able to pull the latch lever back out to the open position, but it might also be necessary to take the door apart to get to the latch to be able to reset it. The real problem is that if it happened before, it will probably happen again. So the real solution is to replace the latch assembly.
May 31, 2015 | Jenn-Air 24 in. JDB2100AW Dishwasher
I have a 1994 BMW 325i and both of my rear doors won't close.. The latches just move freely. Any sujestions?
I didn't see the other posts but did you try to hold the door handle as to open the door and move the latch up so to open all the way. I have seen kids play and push the latch when the door is open and it latches it closed when the door is open and then the door won't latch because it's not on the bar to reset it in the right position, may want to try that.
May 23, 2014 | 2001 BMW 325
Cant close drivers side door
possible that the latch is already in the 1/2 closed position
put a round bar ( screw driver ) under the latch and pull the latch out as you press the handle as if opening the door
Jan 21, 2018 | Toyota Tacoma Cars & Trucks
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
Last night we started the car to clean off snow. Closed the doors. Cleaned the car. Got in and the doors would not close. It appears that the mechanism on the door that grabs and latches the door...
If the latch is in the closed position, simply use a screwdriver to pry as if the door was being opened at the same time as you pull on the handle to open it. This will return the latching part to its proper position and you can then close the door. If the latch is already open and won't close when you shut the door, the quickest way to get it closed is to heat the latch with a blowtorch. Don't get close enough to the door that you scorch and burn the paint but heat the area arond the latch for about 30 seconds or so and the door should latch. You could also do this with a hair dryer or heat gun but it will take longer. Open and close it a few times quickly and it should work properly for a while. To keep it from happening again, once you have it working freely then spray into the latch with some WD-40 or RustCheck. Don't be shy with the spray and get it right into the latch through the door. If it keeps being a problem then before you spray it with a lubricant use a small can of lock de-icer once you have the door working. After that put the lubricant in. Hope this helps.
Dec 05, 2010 | 1996 Pontiac Sunfire
My back doors wont close all the the latch is in the down position ....how or what can i use to fix them the kids push in the latch ..its a 2006 bmw x3 sports edition
TAKE A SCREWDRIVER OR SOMETHING TO PUT IN THE GAP IN THE LATCH WHERE THE STIKER IN THE DOOR JAM IS WHEN IT IS CLOSED NORMALLY,& WHILE YOU HAVE THE SCREWDRIVER OR SOMETHING SIMILAR IN THE LATCH,PULL TOWARDS THE CAR WHILE YOU PULL THE HANDLE LIKE TO OPEN THE DOOR AS IF IT WAS CLOSED NORMAL,& IT SHOULD OPEN THE LATCH.
Dec 05, 2009 | 2006 BMW 3 Series
Door wont close
MAKE SURE THE DOOR LATCH IS NOT IN THE LOCK POSITION OPEN DOOR PULL THE INSIDE LATCH TO THE POSITION WHERE YOU WOULD TO OPEN DOOR AND TAKE FINGER AND TRY TO MOVE THE LATCH TO ANOTHER POSITION , HOPEFULLY TO THE POSITION WHERE IT WILL RECEIVE THE STRIKER POST OR THE PART THE DOOR WOULD NORMALLY LATCH ON
Feb 24, 2009 | 1991 Dodge Grand Caravan
The drivers side door won't close.
open the door , look at the latch on the door , as it get older and non lubricated , the latch can stick in the locked position , i,m going to draw a picture .
when the door is open it should look like the picture , i suggest your door is in the closed position and why it bounces off as you say , take a , lets say a screw driver stick it in where the little lever thats sticking up , push the door open button on the outside door handle , pry that lever forward , if successful try it , and lubricate it , hope my barbaric picture gets the point across .
Jan 05, 2009 | 1995 Jeep Grand Cherokee
Latch stuck after each load
Hello bittoner
Welcome
You said,The latch remains in the door closed position after each load. I can manually reset it by taking the cover off and it works fine until after it runs a cycle and I open the door again. Is this a latch problem or a electronics problem. Note, I have replaced the latch assembly about a year ago for a different reason
Try to turn off the breaker for the washer for 5 minutes and see if the system reset.
If not the electronic door switch sensor is bad
Let me no how it goes.
Huuum
Please remember to leave a rating!
Oct 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
See all AEG 18 in. Favorit 54750Vi Slim-Line Built-in Questions
AEG 18 in. Favorit 54750Vi Slim-Line Built-in Dishwasher Logo
415 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
