I have Panasonic NV-JF620 VCR and in Australia. The play back is jittery. Few months ago it was working OK. No damage. The picture is coming as small sections and jittery. Audio is ok. Tried it in 2 TVs. The result is the same. Checked SP/LP, PAL system but does not improve. Please suggest.
    Brigadier General:
  • 6,966 Answers
Possibly either a tracking problem or the video heads are dirty. Please try a head cleaner which looks like a VHS tape but is meant for removing any dirt on the video head. Most models come with a liquid solution. Tracking normally is automatic nowadays, however, there are some variations and manual tracking (or bt the remote) should correct any jittery images.
If neither of the above is corrective, then your unit would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 20, 2008
Why does my Panasonic NV-SD200A play for 4 seconds then stops and has no kind of output?
General when the electronics detect a fault all functions will stop to prevent damage. Check inside look for broken plastic parts in the mechanism.
Aug 10, 2014 | Panasonic Televison & Video
Why does my vcr play, fastforward and rewind for 4 seconds then stops for no reason?
When the mechanism is damaged the VCR will attempt to play and then shut itself down to prevent any further damage. If you remove the top cover and look around inside you will probably find the cause of the failure.
Nv-hv60 panasonic gone dead
Its dead...what can't you understand here?
Feb 02, 2013 | Panasonic NV-HV60EB VHS VCR
I have acquired a Panasonic NV-FJ620B-S Video Cassette Recorder which has 2 x scart sockets on the back. 1 marked AV2 DECODER/DECODEUR(EX) the other AV1 (TV). The AV1 scart connector works fine on the TV...
Have just visited the Panasonic UK website and the User Manual for the Panasonic NV-FJ620B-S is available free. It lists on page 11 all the details. I'll e-mail it you Tom to see if it helps.
Jan 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
@hotmail.comsir i got panasonic nv-fj620b-k vcr, when i connect vcr with tv i have only audio not video, kindly let me know which type of cable i may use to get connected properly regards
Depends how you are connecting at the present. If you use a Scart, make certain it's a good one as the pins are easily damaged and can cause loss of picture.
Dec 01, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a Panasonic NV-FJ600 VCR which ejects every cassette which is loaded , and the two guide rollers remain at the rear of the machine and do not move forward to engage the tape .
If you mean the guides are on either side of the head drum, and the carriage is in eject position, the mechanism is out of alignment. Re-alignment and re-timing may require a workshop service by a professional Panasonic agent.
The bad news is the likely cost(s) involved if parts are replaced.
The NV-FJ600A VCRs were good models a few years ago, one of the first 'super long play' series Panasonic launched.
They use the Z-mech series of decks. These are not impossible to re-align/re-time, unlike previous mech designs, but depending on the extent of wear/damage, can prove uneconomical for a budget VCR which would now be close to 10 years old.
Oct 18, 2010 | Panasonic NV-HD680 VCR
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Jan 31, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic TV: TX-28DTX10,VCR nv-HV60 EB, DVD:SC-HT 520
EC means euro connector, I.E. Scart socket. For some reason there is no video signal coming out of the scart cable/out of the VCR or being displayed on the TV. Try plugging the scart plug into a different scart socket and see if that helps.
Sep 14, 2008 | Panasonic TX-32PL10 32" TV
Panasonic NV-HS1000 VCR problem
Before you try anything too elaborate, change all of the belts. There are a number of safety features built into this unit to prevent the tape from getting damaged. If one of the reel tables is not turning when it should, the unit will shutdown. There are a number of similar checks made continuously as the machine runs. If you have no experience with these units, bing it in for service. The parts should not be more than $5-$25 total. Add in the local labor charge for the total repair bill. Basically this unit should be cleaned and the alignment checked after the belts have been changed.
Dan
May 23, 2008 | Panasonic NV-HS1000 S-VHS VCR
Problem taping on vcr from panasonic nv-gs50
if you are using rca cables let the cam playing something you recorded and try find the channel on vcr(on its tuner).it would be helpfull if you post a picture of your cord
Nov 03, 2007 | Panasonic NV-GS50 Mini DV Digital...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
