Question about HP OfficeJet 7410 All-In-One InkJet Printer
Connection to network
Wireless connection OK to router: added WPA key and connected ok. 'Add printer' not finding printer
  • 106 Answers
try to use the Software CD to add the printer driver. Choose, "ADD A DEVICE" when window pop-up after inserting the SW CD, then follow the steps to install the device. That should work.
sincerely yours,
Posted on Jul 21, 2008
Can't connect to internet by wireless usingTIME SMART ROUTER 5815H alltough showing connected by (wlan)
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :-
Dec 03, 2012 | Computers & Internet
Setting up Epson Stylus SX515w on a PC.
0 false 18 pt 18 pt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-ansi-language:EN-US;} This guide will show you how to setup the Epson Stylus SX515w, without using the setup CD & USB cable.
1) Using the Control Panel on the printer, press the Spanner/Screw driver button.
2) Scroll though the menu until you see Network Settings & press ok.
3) In the following menu select Wireless LAN Setup.
4) Then select Advanced Setup.
5) Then select manual Setup & press ok.
6) This guide assumes you are connecting through a router via Wi-Fi, in which case you will need to select Infrastructure Mode and then press OK.
7) Select Search SSID & this will search for your wireless network.
8) If your wireless network is showing, make sure it is highlighted then press OK.
9) Now you will need to enter the encryption type, this will depend on the length of the wireless key. WEP 64 Hex (10), WEP 64 Alpha (5), WEP 128 Hex (26), WEP 128 Alpha (13). Any router that has 8 characters I would normally recommend selecting WPA PSK TKIP UNLESS you know that the key is WPA PSK AES.
10) Now you will need to input the security key depending on which type you have, as advised above.
11) Once the key is in correctly you need to press OK. You will then see a Confirm Settings screen. Press OK on this screen and YOU MUST WAIT 30 SECONDS for the printer to establish a wireless connection with the router. After the 30 seconds please go down to Confirm Settings and press OK. This will tell you if it has successfully connected to the router. At this stage you need to make a note of the IP address. This normally starts 192.168.x.x
12) On the PC the printer will need to be installed, I recommend downloading the driver from here:
13) Once installed go to Start > Control Panel> Printers (This will vary slightly depending you version of Windows).
Right click on the printer, select properties (Printer properties for Win 7). Select the ports tab and add a new port.
When adding a new port select Standard TCP/IP, then click add new port.
NB The Standard TCP/IP port is recommended when assigning static IP address to the printer. (See router documentation on assigning static IP address).
If using a dynamic IP Address I would recommend downloading and installing the Epson net printer port. You can use a Standard TCP/IP port, however when the IP address changes communication between the printer and PC will be lost.
Setting up both port types are the same, once you select add port you will need to enter the IP Address, which we noted down previously from the printer. Once entered keep clicking next, then finish.
You should now be able to print over the network. To use the scanner over the network you will need to open Epson scan settings, (a separate utility to Epson scan) this will need to be set to network and contain the same IP address noted down earlier for the printer.
If you still have issues check your firewall and router settings, i.e. mac filtering etc.
on Dec 11, 2009 | Office Equipment & Supplies
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
HP Photosmart c6380 wireless printer works fine, but windows xp does not recognize the scanner
  • First, we need to create the Ad hoc network that will provide wireless connection between your computer and printer. On the right hand portion of the Taskbar, you can right-click the wireless icon and choose "View Available Wireless Networks". Or you can double click the wireless icon, then click "View Wireless Networks". It is also accessible from the Control Panel. Either way, the same window as shown in step 2 will pop-up.
  • 2
  • setup-xp-via-ad-hoc-1.2-120x120.jpg View Wireless Networks The Wireless Network Connection window shows you all the wireless networks in range including the network where you are connected. If you have many neighbors with wireless networks, it will all show up. Click "Change advanced settings" and it will bring up the Wireless Network Connection Properties window. Choose the "Wireless Networks" tab and at the bottom click "Advanced" button.
  • 3 setup-xp-via-ad-hoc-1.3-120x120.jpg Wireless Networks Properties From the Advanced option window, choose "ad hoc" networks only. This is just to simplify the process. You should also bring this back to original setting after you are done connecting via Ad hoc. You may choose to skip this step if you wish and you should still be able to make the connection without a problem.
  • 4 setup-xp-via-ad-hoc-1.4-120x120.jpg Create the ad hoc network Click the "Add" button and type in a name for your Ad hoc network. Make it more intuitive so you can easily recognize your own network just in case there are other Ad hoc in range. Check off the automatic key and enter a 5 or 10 digit network key. This is the same key that you will input at the printer later. Click OK and then OK again. You are now connected to the Ad hoc network. You are half way through.
  • 5 setup-xp-via-ad-hoc-1.5-120x120.jpg ad hoc network Make sure the printer is ON as well as the wireless radio button. On the printer control panel, press the setup button to access the menu. Go to Wireless Menu and press OK. Press the arrow to go to Setup Wizard and press OK so the printer will automatically search for wireless networks in range. From the list of networks, find the SSID or Ad hoc name that you created and press OK and type in the network key using the alphanumeric keypad on the printer. The printer should confirm the connection in less than a minute. That's it! Try to print a test page to make sure everything is working properly.
  • Dec 06, 2010 | HP Photosmart C6380 All-In-One InkJet...
    How to hook up the wireless feature???
    Press the wrench key on the printers front panel and then look for wireeless option or network option in the menu..Press ok on wireless menu or network option and then look for an option Run Wireless setup wizard by pressing right arrow key...then press ok on that and type in the neywork name of your wireless router known as SSID and after that press ok...then type in the security key of your wireless router known as WEP or WPA Key,,press ok.. it will attempt to connect and wil give u a message run the software on computer and select wireless install option on computer and follow the instructions
    Sep 02, 2010 | HP Officejet 5610 All-In-One InkJet...
    I want to use my d-link router with my new acer laptop but cant connect to the router. Windows says it is a router connection problem. It can locate the router just wont allow me to connect.
    1.In Control Panel, click Network and Internet Connections, and then click Network Connections.
    2.Right-click the Wireless Network Connection, and then click Properties.
    3.On the Wireless Networks tab click Add.
    4.In the Wireless network properties dialog box, enter the SSID "(Name of the connection) ex. dlink1234" you configured for your wireless gateway
    5.Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway. (WPA-TSK, WPA2-TSK, WPA-AES and WPA2-AES)
    6.Click OK and your home network will be added to the list of preferred networks.
    if you have a firewall in your laptop try to disable it. example Eset Security antivirus Firewall. Disable the Firewall.
    Aug 25, 2010 | D-Link (DI-784) Wireless Router
    It wont print wireless
    We have to connect the printer to the network first, If it is not connected, please follow the below steps.
    1. Touch Setup (c01629002.gif ) on the touch screen.
    2. Scroll down in the Setup menu, and then touch Network .
    3. Scroll down in the Network menu, and then touch Wireless Setup Wizard . The Wireless Setup Wizard searches for networks, and then displays them in a list.
    4. Touch the name of your network.
    5. If the list does not contain your network name, follow these steps to enter it manually:
    6. Touch Enter New Network Name (SSID) .
    7. On the on-screen keyboard, touch the appropriate letters and numbers to enter the network name (SSID). NOTE: Make sure that you enter the uppercase (capital) and lowercase (small) letters exactly. Otherwise, the wireless connection fails.
    8. When you finish entering the new network name, touch Done , and then touch OK .
    9. Touch Infrastructure , and then touch WEP encryption or WPA encryption. If you do not want to use encryption (a security password), touch No, my network does not use encryption , and then go to step 6.
    10. If prompted, enter the WEP or WPA key:
      1. Touch the appropriate letters or numbers on the on-screen keyboard.
      NOTE: You must enter the exact uppercase and lowercase letters. Otherwise, the wireless connection fails.
    11. When you are finished entering the WEP key or WPA key, touch Done and then touch OK to confirm. The product attempts to connect to the network.
    Once it is connected to the network or if it is alreday connected, please follow the below steps on the printer.
    2. Touch Network , touch View Network Settings , and then touch Print Network Configuration Page .
    After that, please note the ip address of the printer from this printed page and follow the below steps.
    Please click on Start------Control Panel---Printers Folder.
    Right-click on the printer icon 8500 series---- click " Properties" , and then click the Ports tab
    Click Add Port .
    Click TCP/IP port and put (ip address of the printer)
    , and then click New Port . The Add Port wizard starts.
    Click Next ,
    Follow the on-screen instructions to finish adding the port.
    The issue will be fixed.
    Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    Printer asks for wpa passphrase I enter the correct passphrase but the printer says it is wrong
    You will need to check the wireless settings of the router .
    Is there any computer connected to the router with the Ethernet cable?
    If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
    Use that password to connect to the wireless network
    Click Here
    for step by step Instructions on how to find the network key
    Jan 12, 2010 | Linksys Wireless-G Broadband Router
    Wireless problem setup/ What is WEP?
    It is the security key used for your wireless router.
    When you set up any device to connect to the wireless router you will need it.You should be able to go on you computer,open internet explorer,and type to get to your router page to see all the info needed.
    Jan 09, 2009 | HP Photosmart C7280 Printer
    Cannot connect to network with WEP key encryption
    It will not connect to a wireless network with WEP. it supports only the latest encryption. Try changing the encreption on your router to WPA or WPA2
    Mar 17, 2008 | Archos 605 Digital Media Player
    HP OfficeJet 7410 All-In-One InkJet Printer Logo
    113 people viewed this question
    Ben Johnson
