Question about Gateway GT4016 Desktop PC
Video Card Recently my video card has malfunctioned... About a year ago my sound card messed up and i purchased an aftermarket and it works perfectly. My question is can i purchase an aftermarket video card and install it my self and have my computer running 100% again.
  • 36 Answers
Without knowing the extent of your experience with PCs that's nothing but a guess really, but, yes it is possible, and is actually an easy task to learn with. I would suggest browsing for tutorials or techsites like this one and learn as much as possible before ever trying it. One little mistake can be expensive, but as you get to know your machine you will probably find yourself doing a lot of different upgrades.
It wouldn't hurt to check Google or even your PC manufacturer site to see if these are regular occurences with their products. If so you can replace other small parts while you have it torn apart. Though it is recommended that you only change one thing at a time and test for a while to assure no problems. Some puters are finicky about different parts. I've had it happen with network cards, video cards, and even new hard drives that just wouldn't work. They all worked fine in a different system but it's one of those things that are not predictable and can happen!
I would suggest a good upgrade and/or building a PC guide if you are not sure about what you are doing. An I hope you are successful if you do try it!
Posted on Nov 13, 2008
The Monitor for my Gateway LX6810-01 won't even connect with it, says there is no RGB connection, could it be the video card?
Unless you have installed an aftermarket card in you machine, the computer graphics are integrated on the motherboard. There is provision for installing an expansion video card. If the on-board video has failed, and it is very possible that it could occur, purchasing a compatible aftermarket video card can be a cost effective repair option.
Mar 02, 2015 | Gateway LX6810-01 PC Desktop
Overheating of graphics card while playing games
  • Clogged fan
The main device responsible for maintaining a constant temperature of your video card is the fan present in the processor. If this isn't functioning efficiently it's quite obvious that it would result in your video card overheating. If you don't regularly clean your computer, it could be highly likely that your fan is clogged with dust.
This is one of the simplest causes of your video card overheating which can be fixed by simply cleaning your fan, preferably using a blower.
  • Broken fan
A follow up of the previous point, in some cases your fan maybe malfunctioning or stopped working altogether. This could simply be diagnosed by switching on your computer with its cover open and checking if the fan is functioning. If it doesn't happen to be working, you have your answer.
  • Overclocking
Pushing your CPU to its limits by overclocking can cause your video card to overheat. This can seem fairly obvious too as if you find your video card overheating and if you've recently overclocked your CPU, it would explain it.
  • Faulty Drivers
This is a rare cause, but depending on your video card's brand a badly developed driver could also cause your video card to overheat. If you use an unusual video card with questionable reputation this could be the issue.
  • Inefficient Airflow
While your fan maybe perfectly in tact and working, the location of your fan also matters. If there isn't sufficient air flow to your video card it can also cause it to overheat.
Those are typically the 5 main reasons to your video card overheating. If you have any other points in your mind, feel free to share them below.
May 09, 2012 | ASUS GeForce GT240 1G DDR3 550Mhz
Video card suddenly messes up
That sounds to me like there is a problem with the sony vegas installation, or maybe an entirely separate issue with windows. Butit is highly unlikely that it is a video card issue.
Sep 07, 2009 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
My graphics card is being funky
Well, first I took it out and beated it with a hammer. Then I dumped it in a bucket of my own urine for a good several hours. That actually helped it a lot.
Thanks.
Aug 25, 2009 | Computers & Internet
My video connection does not work monitor says "no signal." I checked all connetions and they's properly connected.
Check to make sure you have correct ram installed in motherboard as the video card may share that ram. Check CPU that it's installed correctly and video should work. If not then the motherboard is bad.
Jun 01, 2009 | Asrock P4I45GV R5 Motherboard
Lost driver for Kreiser ELM-1900BA monitor
what monitor and what video card????
not enough information to help you.
Oct 16, 2008 | Computers & Internet
Problem after loading windows,display???
it could be a problem with the video card video driver,tried going to safe mode,reboot your pc and press F8.Go to safe mode with networking.
Aug 26, 2008 | Toshiba Tecra 9100 Notebook
Very choppy video
Back when P4 systems were common, the hard drive interfaces were quite marginal for video processing and techniques to force the capture to faster devices (like a RAM drive, or now
SSD drive, or SCSI interface to high end striped drives) were used to smooth the video capture. I have had good luck with SATA3 interface SSD's for capturing video, but continue to use a drive other than the one I boot from so windows doesn't mess up the frame rate.
Mar 19, 2017 | Zonet Computers & Internet
Gateway GT4016 Desktop PC Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
