Nokia N73 Cellular Phone Logo
Anonymous Posted on Jul 20, 2008
Installing line comes up after each restart.
Installing line comes after restarting my N73 Me everytime.after few seconds it says,"UNABLE TO INSTALL FROM MEMORY CARD,INSTALL FROM APPLICATION MANAGER." This happened when i formatted my 2GB minisd card but i did backed up my data in the card even the hidden files.and after formatting i restored it and since then after every restart im getting this error.moreover im not able to install any JAVA application like ".JAR" formats.Whats wrong?have i erased some in built factory instalation files for JAVA?cuz when ever i save a java file in fone n try to install it,error comes up that file format not supported..but earlier i was able to install them i.e befor formatting the minisd card.Please help!!!!!!!
  • 4 more comments
  • Anonymous Aug 01, 2008
    i formatted the card through fone only and not thru PC..
  • Anonymous Aug 12, 2008
    u posted no solution amiaka.
  • Anonymous Aug 20, 2008
    ive told already that i formatted the card through the fone only and only once.. i never tried doing it again... n after formatting im not able to install any java file or .JAR files on my fone .. it simply gives an error. "FORMAT NOT SUPPORTED" but when i purchased it,i did installed java n .JAR files an they were successfully installed.
  • Anonymous Oct 02, 2008
    n how would i try that. where can i find another memory card having the same contents as N73?the SYSTEM FOLDER would b a hidden folder?n i have to use the another memory card from N73 for sure?
  • Anonymous Nov 29, 2008
    just do *#7370# n ur prob is solved no need to woorry!!
  • Anonymous Dec 17, 2008
    AFTER EVERY RESTART I M GETTIN "INSTALLING" MSG...
    AND AFTER CERTAIN SECONDS IT SHOWS "UNABLE TO...."
A
Anonymous
Try to copy a system folder from other memory card. sory for not answering your question for a long time coz i was not able to open my email account. sorry for inconvinience.
A
Anonymous
I also faced the same problem, but after formatting memory card through mobile, it runs perfact.. So u should format ur memory card.. then u never faced this problem again.
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Jul 20, 2008
Anonymous
Expert
Level 2:
Answers
61
Questions
0
Helped
8790
Points
116
Did you tried to format your memory card via phone? if not, try it go to tools then select memory card, click option them select format memory card, then try to install some java applicatins. good lack
N73 software ok but unlock not ok
make your phone memory free.
install all application in mmc.
cell never hang / restart ;)
Hi i am unable to update preinstalled version of windows 7 home basic on my lenovo g480. everytime when i shut down, it installs updates and when i restart it tries to configure but then there comes a...
Make sure the account you are logged in as has Admin privileges, and manage updates yourself. Choose and only install those updates pertaining to you. Like not installing languages updates and so on.
Unable to download and install
1. Turn on your N73 phone. Make sure there's enough battery to complete basic operations. Plug it in to a charger if the battery is low.
2. Type pound 0000 pound (#0000#) on the keypad. Press the "Options" button, then scroll down to "Check for software updates." Press "OK."
3. Wait for 30 seconds or so while the phone retrieves software information from Nokia.
4. Select the software you want to install when the options pop up. Some software updates include "Mobile TV optimization," "Map updates" and "Java support." Your phone will only offer you the choices for your device, and you can double-check that each one says N73 next to the title. Make your selection by highlighting it and clicking "OK," and wait for it to download and install.
5. Repeat these steps for each piece of software you want to install until they're complete. Some may require you to restart your phone.
My mobile Nokia N73 gets reboot when any incoming calls come rarely
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Model : nokia n73 screen hangs on the 'NOKIA' banner on restarting everytime and eventually becomes blank...ie white background. have tried removing battery.
First:
u have to restore your set again.
OR:
*#7370#
or:
Very Best Solution:
N73 always restart
It is due to phone's software problem.Re installing your phone's software or updating your phone's firmware can fix the problem.
My N73 gets stuck I have restart it again and again
try doing a reset to factory settings!!
it could be an issue with some new software that you have installed for your phone...
or else try to upgrade the firmware of your phone...
Unable to install windows XP on my Notebook
you can't install Windows Xp from witin Windows vista. (not backwards comparable).
restart the computer press F12 when the HP logo comes up. that will bring you into BIOS. select advace>>boot order.
select CD-ROM as first boot. HHD asn second.
exit the BIOS and restart the laptop with CD in the CD drive.
press enter when the system start to install from CD......
and follow the screen (must reformat the HHD).
1helpful
2answers
Windows mobile unable to see the screen
ASDFGSDFGGSFGGHGFGHGHJKYYYYYYYYYYYYYYYYYYYYYY
How could i remove the warning message when i always open my phone..
hi sir
please restart ur phone by following steps:
  1. tools
  2. settings
  3. phone
  4. general
  5. restore factory setting
it will ask for the password : general password- 12345 or ur security code. it will restart .. it is one solution . if the above solution does not work better u go to: 1. tools 2. application manager view that file and delete it . after u install that . if u still have the same problem.. please post me. i am there to assist u ..
Thank you sir
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
