Question about Fisher and Paykel Washing Machines
Needs serves code 37 - Fisher and Paykel Washing Machines
    Brigadier General:
  • 6,966 Answers
To my knowledge error code 37 indicates fault "pump blocked"
Corrective procedures would require checking the drain pump, drain hose, drain filter. Particular attention must be given to the drain pump impeller as they have been known to stop due to safety pin, plastic and any foreign debris.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 20, 2008
Fault code 37 Yamaha V-Star 1300
Hi, Kenneth for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ERROR code 37
Yamaha Fault Codes
OEM parts for Yamaha
Yamaha 2007 XVS1300AW Owner Manual
Jun 15, 2012 | 2009 Yamaha V Star 1300
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Partion of c and d for a 100 gb dell inspiron recomended portion
Why not just use the totals disk as one big partition? It's much easier and most times people fill up the c partition while the d partition sits there empty.
It would serve you better to have one big contiguous partition.
Jun 04, 2012 | Dell Inspiron 6400 (883585945283) PC...
My ford tarus/1999 'serve engine"
The blinking engine light indicates your problems are severe and could cause more damage to the engine if not corrected. You will need to have a diagnostic scan run to retrieve the trouble codes that are causing the light to come on & flash. From those codes, repairs needed can be determined.
I hope this helps.
Sep 23, 2011 | 1999 Ford Taurus
37" Sansui LCD TV, help with remote codes
Much as I hate to say this, looks like you may need to find a genuine one.
Good luck
Mar 21, 2010 | Sansui HDLCD-3700 37 in. LCD Television
Need codes for Philips flat screen TV model #27PT6441/37 in
U recieved the propeer code from a nother direcTV provideer in my area. It worked when others did not.
Oct 07, 2009 | Philips Televison & Video
Program code for olevia 37 to direct tv remote
the remote control code for DirecTV with Olevia 242T or 237T (37' or 42') model is 11610. this code will power on/off and volume up/down the buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to - accessories - remotes.
Mar 15, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Screen has code 37 on it
Hi, welcome!
Code 37 is a "pump blocked error" code. Typically this code is triggered when the machine does not sense a change in the water level when called for. Check for debris caught in the pump, either in the impeller for moving water or in some cases, the external cooling fan impeller (exposed underneath the machine) gets snagged with a piece of fabric softener sheet (such as "bounce") and this will stall the pump and trigger a code 37.
I hope you find this info useful and thanks for using Fixya.
Jan 26, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Codes for 37
I nee code to set up my universal remote
Jan 03, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Washing Machines Logo
272 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
