Question about Nokia 6300 Cellular Phone
Problem with nokia 6300
I recently got a nokia 6300 for my birthday,but it has a problem and i dont know how to fix
when i go to menu and click for example messages it hardly open
what should i do
  • nokia l Jul 20, 2008
    when should i format my phone,at the shop when i bought
  • Anonymous Jul 20, 2008
    I forgot my pin code and used it over three times and found the phone loched out and ask me for the puk code
Try to format your phone nd memory phone nad if it doesn.t wok go to nokia priority cntre...........
Posted on Jul 20, 2008
In my Nokia 6300 when I try to save the gprs settings it says "only 70 sets allowed, settings discarded" !!! If I restorte factory default or delet some msgs,problem remain same " memory...
Go to Menu
Then to Settings and click
Then scroll down to Configuration and click
Click on Default configuration settings
Scroll to any of the configurations, click options and delete to create space for new ones.
I hope you find this helpful? If not, comment for me to know.
Thanks
Dec 18, 2010 | Nokia 6300 Cellular Phone
Tip
Nokia 6300 "only 70 sets allowed setting discarded"
"only 70 sets allowed setting discarded" is one of the Worst Problem in Nokia 6300 and Some other Models.But there is No Settings Visible in Configuration Settings When we Checking[To Delete it from Phone Menu to Save New Settings].We can't get rid from this Trouble only by Making Restore Factory Settings.
This Settings are actually in Phone's Drive[C Drive] and which is invisible in Phone Menu.So it need to Remove from the Phone to Save or Manually Create New Settings.
This can be Possible through following Steps-Simply do it and Save your Valuable Money.Also make your Phone Active and Cool.
Here is the Steps to Taken to Solve this:
  • Download Oxyfile (To Download Click here)
  • Install it on your Computer
  • Connect your Nokia 6300 with Specified Cable
  • Open Oxyfile Software Click on 'FILE BROWSER'
  • Go to Drive C: (Your phone memory).
  • In folders -select 'Omadm' Folder.
  • There will be 70 Numbered folders under Omadm.
  • Delete all folders except first 5 & the folder named PRECFG.
  • Disconnect your phone.
  • Switch OF your Phone for 2 Minutes
  • Switch ON Phone
  • Now you are Solved
Now you are able to Save OR manually Enter Settings to your Phone.
-Enjoy and Ensure wide Connectivity through your Phone-
I like to Know Feedback too
Thanks for Contacting FixYa..........Don't Forget to VOTE for ME if this Helped you....
"Unable to Open Theme Corrupted" in Nokia 6300 Click here
on Jun 25, 2010 | Cell Phones
Sir how i can set my picture as a screen saver when my mobile phone nokia 6300 command unlocked.
i dont know what you mean by command unlocked,,but if you open pix and click options you should get option use image as,,even without opening pix just select it and press options (the key on your top left above call key)
Dec 08, 2009 | Nokia 6300 Cellular Phone
Format phone memory of nokia 6300
click main menu, go to settings and click the restore factory settings or reset settings. click it and enter the master code 12345. your phone memory will be formatted. now your cell is on the actual and jenuine factory settings.
Jul 21, 2009 | Cell Phones
Restriction code nokia 6300
Unlocks.co.uk can supply a restriction code for the Nokia 6300 from only £3.00. Ordering an unlock code for your Nokia 6300 is very simple - click on the Nokia Unlock Codes link in the menu, select Nokia 6300 from the list, complete the secure online order form, complete your payment through the PayPal payment service and sit back, relax and wait. Your Nokia 6300 unlock code will be delivered via email usually within 24 hours, however please allow up to 7 workings for delivery.
Jul 09, 2009 | Nokia 6300 Cellular Phone
How to format my phone?
Hi Friends,
Having problem with Nokia 6300? Don't Worry. There is a site where you can easily fix your problem.
Mainly Nokia 6300 problem is for Unlock Code, Puk Code and other Lock Codes. If you are searching for such codes you Must Click Here.
There are also some problem with Nokia 6300. Such as software problem, hardware problem etc. If you having these problem you can Click Here. May you find your solution.
Jan 05, 2009 | Nokia 6300 Cellular Phone
Can i get my nokia 6300 unlocked :( :( ?
you need to use a software box to open your phone, it as available inthe shops near you.
Jul 19, 2008 | Nokia 6300 Cellular Phone
Security code for nokia 6300
hi,
The default security code for Nokia is 12345.
You can recover the password. The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It’s for series 60and 40. The trial version should be enough. In the file manager (when installed on your phone) you’ll find under- C:\System\mmcstore -the file you’re looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via luetooth or USB, open it on the other phone and your password will be revealed. Rename that file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card. If you reset (format) your phone you will lose all the data stored on it. Resetting sometimes gives negative results. You can reset it through your menu, if you can switch the phone on of course.
Using the reset code is not recommended,So keep this as the last choice.
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset. Switch it on..Thank you!!..
Jun 18, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
