Question about Samsung Microwave Ovens
Samsumg CE283GLT does not power on
I have connected the microwave to mains but it does not power on. I checked the mains and have power.
  • Samsung Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can order Samsung parts here. To find an authorized Samsung servicer, see this page.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
How to replace fuse Samsumg microwave me179kfetsr/ac
This is a goody---you have to take the cabinet off then over by the control board you'll see a small circuit board with a donut coil magnet---on that is normally the fuse but it maybe on other circuit board----DO NOT MESS WITH THE MAGNATRON--DO NOT LEAVE IT PLUGGED IN WHILE WORKING ON IT---GL
Sep 19, 2017 | Microwave Ovens
Microwave would cut off after a few minutes and then turn back on but now there is no power at all.
There are few reasons for this fault, but the main is that you need to open your microwave oven and first check the Fan which is connected at the back which cools the magnetron.
If this fan fails thus results in magnetron being overheated and the thermal cutoff gets open circiut and shuts down whole power of your microwave oven.
Check your fan motor test it straight with direct power
Also check the thermal cutoff.
Let me know after you have done those checkups
Regards
Ashwin
May 22, 2015 | Magic Chef MCD1611ST Microwave Oven
Jmv9169bas
Hello, Sounds like the transformer may have problems. There are very high voltages even in a microwave that is not powered up. Be carefull. It is between to take into a shop to have repaired.
May 31, 2014 | Jenn-Air JMV9169BAS Convection Microwave...
Why is my microwave dead?
Assuming you checked the main fuse (inside the case, near where the power cord enters), you might have a bad connection to the (main fuse) fuse holder. Sometimes these heat up and oxidize. Some thermal protectors operate seemingly backwards; in that they are normally open, and close when certain conditions occur (such as a fire in the cavity). Make sure all door switches actually function properly by checking them with an ohm meter. Although extremely rare, power cords sometimes fail.
May 09, 2014 | Microwave Ovens
The door of the combination oven microwave slammed shut and the oven lost all power
check the main cable of mven maybe its Rupture test it if it give 220v ac or 110 vac
if it ok then check fuse bass wich the cable connect on it maybe it damaged
Nov 27, 2013 | Bosch Microwave Ovens
Child lock on
This feature detects when your child pushes various buttons.
To reset/remove this message, disconnect the microwave from the mains power, wait for 30 secs and connect it to the mains power then set the Time and your microwave is ready for use.
Jan 22, 2012 | Panasonic Microwave Ovens
When I try to use microwaave I get a message DOOR
It seems that the safety door switch which is normally a two pronged LIMIT switch is fault or out of SYNC with the door lock circuit. Now unless the switch contacts and resets the main processor board the microwave output will not be activated - this is a safety feature to ensure that the microwave does not work with an open door and be harmful with the HF on human.
So please remove power, check the contacts on the door switch, replace the switch if contacts are open or realign the switch to contact.
Also check the linking cord to the main board from the switch, check the connection pins.
Sep 19, 2011 | KitchenAid KEMC377KSS 900 Watts Convection...
My micro own is no work on this time.i have no customer no of samsumg
Check the plug, the socket and the lead, that is all the advice I can give you at the moment. A microwave is an extremely dangerous appliance and any further unqualified work on this appliance could be lethal.
Jan 17, 2011 | Microwave Ovens
We urgently need Instruction Manual / owner's Manual (original booklet) of our newly purchased Microwave Oven having Model "CE283GLT/XTL" (Product Serial No.:09317DEL900334D) as this Manual is not...
hi, here is the link to the manual of your microwave
http://downloadcenter.samsung.com/content/UM/200709/20070914093233421_CE283GL_XTL-02976H_EN.pdf
kind regards
Mar 11, 2009 | Samsung Microwave Ovens
Microwave portion malfunction
Did you mean that the microwave oven won't turn on at all?Did you try replacing the fuse?
May 24, 2008 | GE Advantium SCA1001SS Convection /...
Microwave Ovens Logo
205 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
