I'm guessing the HDD needs to be reformatted. To reformat... ALERT THIS WILL ERASE EVERYTHING ON YOUR HARD DRIVE. if there is import information that is not backed up, back it up on a computer that recognizes the drive. Go to control panel in the start menu, then to system and security, then Administrative tools, then computer management, then storage, Disk management,
This will list all storage devices that are connected to the computer. Based on the names you should be able to tell which one is the western digital. Right click, format and follow the formatting wizard. Format the drive as NTFS. Allocate all available space to 1 NTFS partition unless you would like multiple partitions.
Your disk is formatted using FAT32 file system. FAT32 has a maximum single file size of 4GB. Reformat your drive using NTFS file system to enable file saving larger than 4GB.
To reformat the drive: -insert external drive - open "My Computer", point your mouse over the drive letter of your external drive, right-click and select "Format". Select NTFS from drop-down menu under "File System". -click "Start" button
Please note that all data will be deleted so please backup your files before formatting the drive.
If you are using Windows Vista then format your external drive with exFAT (Extended File Allocation Table, aka FAT64), or NTFS. And if you are using Windows XP then only solution is to format drive with NTFS file system. How to do that, just right click on HD from My Computer an click format.
Fat32 is yesterdays file system and is mostly used for small partitions and flash drives. Always format new hard drives in NTFS. The hard drives for the most part don't care what backup utility you use.
Win 98 does not support plug & Play USB devices unless the drivers are installed. Xp how ever does. you need to install the drivers to be able to used the device in win 98. since you did not get a driver cd, best would be to download the drive from the net. if you abl to give me more details of the device, i would be able to find the driver.
