Question about HP Compaq Presario V6000T Notebook
Presario V6000 laptop
When the power button is pressed the only thing that happens is the lights lightup and nothing else then after a few seconds it shuts down again, nothing comes on the screen at all and the fan is not running, no sound from the unit itself, just lights up then shutsdown again, the battery is 100% charged and ive tryed booting without the battery but still no joy.
any idea's?
  • Andrew Fisher Jul 20, 2008
    would the same situation accour if the battery on the motherboard was flat? i cant take the drive to another computer as i dont have the required cabe to hook a laptop HDD to a tower. im guessing that the software is accesable is it was working fine lastnight untill it was turned on today.
  • Anonymous Jul 30, 2008
    I have the same problem and so the HP company that produced this product. Here what they say:
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • 476 Answers
Sounds like a motherboard issue ,
can you take the drive to another computer and check the contents are still accessible.
If contents are accesible then the motherboard is poked.
replace device and start again.
There is no cheap fix for this one unfortunately.
Keep me posted with your outcome thanks
Posted on Jul 20, 2008
  • Verne Koti Jul 20, 2008
    the battery on the motehrboard is there to retain the settings and passwords for the installed system,even if you replace the battery the problem would more than likely still exist,
    Removing the battery long enough would reset the stored settings and clear this memory function.
    You can purchase a USB 2.0 to IDE Adapter Lead ,
    2.5" hard drive (laptop size) lead for the testing function,
    Theyre reasonably cheap for the job it does then you can use a standard pc usb to test the drives functionality,
    IMPORTANT NOTE for USB 2.0 to IDE adapter laed
    If you get the lead pay particular attention when connecting the laptop drive to the connector,
    if its around the wrong way you could fry the drive,
    there are no markings to tell which way the correct way is.
    How to Identify the correct position for this lead
    Hold drive in your hand looking at the exposed pins at the end,
    There should be two rows
    look at the center of the two rows,
    should be one complete row and one with missing pins.
    turn the missing pins side to the top
    take the adapter in the other hand,
    there is a notch in one side for 3.5" hard drives
    turn the notch to the top face notch towards you
    line up your pins
    connect to drive,
    should fit on without removing hard drive holder.(mine does)
    Let me know if this helps,thanks
Does nothing when i try to switch 'ON'. i press a few keys on the board and F12 light comes on
That is the classic symptom of GPU damage caused by overheating. Seek a GPU re ball repair.
Nov 07, 2015 | HP Compaq Presario CQ57 Laptop
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
May 03, 2010 | Compaq Presario 5000 PC Desktop
My compaq v6000 will not power on. Power on light comes on for 3 seconds and then cuts off. Got another battery and still will not turn on. What can I do?
unplug the battery and charger hold your power button pressed for 1min then plug it back in and try to boot ,if no joy and stil under warrenty contact reseller ;)
Mar 11, 2010 | HP Compaq Presario V6000T 15.4" Notebook...
My compute will not turn on
The laptop might be overheating, sometimes when the laptop cant get any ventilation it shuts down and will not properly power up till the temperature issues are delt with.
But you usually get at least a few seconds of power before it shuts down again, so it may not be that, sounds a bit more like the CPU is dead and will need replaced.
Jan 03, 2010 | HP Compaq Presario CQ50-110US Laptop
Compaq Presario V6000 not turning/powering on
This can be a tricky problem indeed. As a matter of fact, I'm experiencing a similar problem myself. I don't know if you have done this or not so I'm going to throw it out there:
Have you tried plugging it into a charger and starting it? If so, how about without the battery?
Also, if the laptop isn't charging, check to see if the charger is faulty. The end could be bent, or something inside could simply not be working.
The most likely problem if none of these help is that the port itself is shot. In that case, you'll have to take it to a computer shop and have them diagnose it for you just to be sure.
Hope I was of assistance.
Nov 28, 2009 | Computers & Internet
My Compaq v6000 notebook doesnt power on it just
You could be having a problem with your power source....(not the plugin) but the actual power unit inside of the laptop. Or could be dirty inside and sometimes they get touchy with a lot of dust build up. Try cleaning out the inside of the laptop be removing some panels on the bottom and the keyboard. Try using a can of air to blow the crud out.
You can also take it to a shop and have them test the power source.
Sep 19, 2009 | Compaq Presario Notebook
When I turn my V6000 on, I have power lights and the fan starts for 5 secs then shuts off. Nothing appears on the screen!
Sorry to hear about your V6000 problems.
If this problem has just started and all was OK before this happened.!
1. Remove all media from drives.
2. Remove battery and A/C power input.
3. Flip unit over and remove the memory.
4. Disconnect the CMOS battery.
5. Remove the Hard Drive.
6. Flip unit over and Press the Start Button for 30 seconds.
7. Flip unit over again and re-install the Hard Drive, Memory and last, the CMOS battery.
Note ...
8. Reconnect the unit to the A/C input supply voltage.
Leave the battery out for NOW !.
Flip unit and try to start with the Touch Pad Led's. This should bring up Quick Play.
If your unit starts and you here several beeps,
Don’t worry, !! You should be able to access the BIOS screen. You can reset your date and time.
If you are still not able to start unit, drop me a email and I will try some other ideas.
Hope this works for you. !!
Try it, It may work !!
John Ray
john@johnrraycomputer.com
Readers please rate your information, even if you disagree, it shows the technician, you care enough to respond.
Thanks.
Jul 09, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
Not starting up
sounds like a dead processor
Jun 14, 2009 | Compaq Presario Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
HP Compaq Presario V6000T Notebook Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
