Masque Publishing Winemaker Extraordinaire Logo
Posted on Jan 31, 2011
I can't get Winemaker Extraordinaire to load in career mode. Free mode runs just fine. I have updated everything from DirectX to java to no avail.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1466
Points
8
Hi, I have had the same problem...its because of new version of Adobe Flash Player...you have to delete opening_cs from cutscenes...then career mode is working on my computer, but I am not 100% sure, that will be working till the end of the game....but you can try :)
2answers
Will an a4tech web camera work with windows 8
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Jan 16, 2013 • A4tech PK5
No driver
Install a4tech pk-7g without cd
Can not enable webcam
I try to start career mode under current customised the game just freezes.
TRY TO UNCUSTOMIZED THE SETTINGS AND TRY THE GAME AGAIN, SOMETHING IN THE SETTING PROBABLY AFFECTED THE GAME.
Farmville is in loop loading
Adeline,
I do not know much about farmville, however since it is a web-based app, these actions should correct the poor behavior.
1. Run all of your Windows Updates. In Windows 7, click the start button and type "Windows Update" into the search area. Click the Windows Update and run all of the available updates for your computer.
2. Reset Internet Explorer. To do this, in Internet Explorer, click Tools>Internet Options. Click the Advanced Tab and the click the Reset button.
3. Make sure Java and Flash are up to date. To update Java, visit www.java.com
and to update flash visit www.adobe.com
Once you have run all updates, reset IE and made sure java and flash are up to date, try the farmville app again.
If it still fails, then you may have a virus or other sort of malware infecting your machine. Microsoft makes a free software that you can install and run to detect viruses. It is called Microsoft Security Essentials and can be downloaded here: http://windows.microsoft.com/en-US/windows/products/security-essentials
Hope this bit of info helps!
How do you replay the tutorial/instructions on the WinemakerExtraordinaire cd?
there has to be a readme file on the CD, just open the content of the CD and look for it, you'll find it for sure. or maybe you can find the tutorial online, use google ;)
3helpful
When I select career mode from the menu, the game errors out and closes. How do I fix this? I played the game all the way through quite a few months ago without any problems!
Hi, I have had the same problem, its because of new adobe flash player....you have to delete opening_cs from the folder cutscenes, then you can play career mode...I am not sure, if it will be working till end of game, because I am just at beginning, but you can try :)
Top Masque Publishing Computers & Internet Experts
Billius
helencardona
helencardona
Are you a Masque Publishing Computer and Internet Expert? Answer questions, earn points and help others
