Question about Toshiba Computers & Internet
Says cant detect battery - Toshiba Computers & Internet
    Novelist:
    Scholar:
  • 160 Answers
There is a "CMOS" battery on the motherboard, it sounds like it has lost its power.
CMOS maintains certain system settings, such as the date and time when the computer is powered down.
If you power off the computer, open the case and look at the motherboard, you'll see a flat battery that looks like an oversized US Quarter. Get the number off it, go to a local Walgreens or hardware store and buy a replacement. Just put it back in the same position (usually with the "+" up.
You'll have to enter the bios routine (press "DELETE" on boot up, and enter the date and time) the first time you boot after replacing the battery. Look for the "Save Settings and Continue" message on the BIOS configuration screen.
These batteries need to be replaced every 2 - 4 years depending on your luck.
If that doesn't work, please let me know, and we'll explore other ideas. If it does, please mark this question as a "Fixya"
Good Luck,
airoff
Posted on Jul 20, 2008
Why doesmy LG vs910 display "usegenuine battery" power off, and has a ? In battery. Bar?
your Lg phone has detected a non- Lg mfg battery installed inside it , the ? in display is to "say" hey I don't know power level as I cant interface with this battery
Jan 15, 2016 | LG Cell Phones
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
When i detect the power when the battery is flatt then the screen just flashing. I cant solve this problem! What can I do?
the battery cell is weak
replace the battery with a new one (original)
and see if problem continues... keep me posted
pray it works
Jan 25, 2011 | Cell Phones
Hi i have toshiba p305-s8830 i have new battrey but battrey cant be detected from the computer ?
If the original battery can be detected (even if it no longer holds a meaningful charge), and If the "new" battery is a 3rd party manufacturered one - and most of them are - it (the new one) may very well have been dead to begin with. Now please realize that these notebook batteries are not just a bunch of cells connected or wired together - it's a lot more than that, as there's also a circuit board between the battery contacts and the cells, and this circuit board almost always contain some form of propriety stuff that 3rd party battery manufacturers have to "reverse engineer" to be as close to the original specs as possible, and this reverse engineering stuff ain't always perfected or tested fully.
If I were you, I'd return it, get a replacement, and if the replacement is still not detected, I'd go with some other brand /manufacturer. This kind of stuff happens quite often.
Nov 13, 2010 | Battery Technology for Toshiba Satellite...
My nokia n73 phone is damaged while doing software upgrade . now my computer cant detect my phone. only light in phone screen. i tried to remove battery and restart my computer many times but still cant...
visit the nearest Nokia Service Center in your area and have the do the upgrading of your software. One possible cause of this cellphone damage is due to interrupted internet connection, which may occur during software upgrading.
Nov 03, 2010 | Nokia N73 Cellular Phone
Laptop cant detect discs
Hi, Unfortunalty this is an hardware failure there is nothing you can do. If you are under warranty i suggest you to contact the reseller/manufacturer to get a replacement unit, it should be no problem at all this is a common issue. HDD,batteries,power adapter are the weakiest part of your system and generate the heaviest part of hardware failure on computers.
Thanks and have a nice day J -
Jun 09, 2010 | Computers & Internet
Usb device over current status detected shotdown in 15 second. cant acces the bios
Pull the little battery on the motherboard, and unplug the PC, let it sit for a minute or so. Put the battery back in and turn it on, BIOS should be reset.
Oct 01, 2009 | ASUS P5PE-VM Motherboard
Nokia 6300 cannot be detected by my computer when
The PC seems to be OK. The phone switches off and hence can not be detected. You cant detect a dead device. Try a different battery. Or try using the charger while connectiong. If it does not go off then the battery is at fault. Change it. If nothig is detected faulty, then uninstall PCSuite . Restart the PC and re-install PCSuite without connecting the phone. When you connect the phone afterinstalling the SW, he phone will be detected immediately.
Aug 05, 2009 | Nokia 6300 Cell Phone
My nokia 6500 cant detect my micro sd memory 1gb.. plz help
hi, i got the same problem and got to solve it. Try this...
1. the battery cover must be put on otherwise, the hp won't detect the memory.
2. try to fix the cover or hook by bending it.
Good Luck.!
Feb 18, 2009 | Nokia 6500 Slide Cellular Phone
Not detected by pc
Sounds like either your motherboard is failing or your battery is starting to fail. If the battery is shot then the unit will not be able to properly connect with iTunes and will not be detected by iTunes. If you need additional support options or want to recycle that iPod, let me know.
Rick
EverGreen Electronics
Mar 09, 2008 | Apple iPod nano
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
