Question about Sharp AR-5320 Black and White Copier
Horizontal black and white lines are coming on copy
I have AR-5320 Sharp Copier. It give horizontal Black & Whitle lines on the paper. the lines come after 3 or 4 inches.
  • lenient02 Sep 05, 2008
    i have two Sharp AR-5320 Black and White Copier, and both of them are drawing lines on the copy after i have serviced both of them for the first time. please i want you to help me and tell me what i will press to adjust the sharpness of the drum of the copier, so that the photocopied work will be sharp and stop drawing the lines.
    thank you sir.
    my e-mail address: lenient02@yahoo.com
    Scholar:
  • 53 Answers
You don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Posted on Jul 20, 2008
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
AR-5320 Black and White Copier: new 5320e no photocpies but print out blank paper...
hi dear may you dont have put the origenal document proper or may be blank, just put writing side down on the glass or if u are using ADF put the writing side up side,
thanks
May 18, 2010 | Sharp AR-5320 Black and White Copier
My sharp copier tears papers and creates a black line on the pages.
I believe you may have a slight paper jam. There may be a slight junk of paper or it is not inserted perfectly straight.
Nov 12, 2009 | Sharp AR-5320 Black and White Copier
Brother MFC has a horizontal white line. What is the problem? new drum installed and fresh toner.
(1) Check the paper used meets the recommended paper specifications. A rough
surfaced paper, damp paper or thick media can cause the problem.
(2) Check that the appropriate media type is selected in the printer driver.
(3) The problem may disappear by itself. Try printing multiple pages to clear this
problem especially if the machine has not been used for a long time.
(4) The drum unit may be damaged. Install a new drum unit.
Mar 12, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Copier giving L 4 error alternately
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Sep 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
Sharp Softwear 5320
Sir,
How can install Sharp AR-5320 Black and White Copier in win vista. i have only win XP driver cd.
thanks
Aug 11, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
519 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
