Question about Namco Ace Combat 2 for PlayStation 1
Ace Combat 6 trouble seeing targets
The target boxes on my HUD seem to blend in with the terrain making them extremely difficult to spot and almost impossible to read the target name (tank, AA gun, etc.). what can i do fix this? if it helps, my TV is rather old but other games work fine
  • 375 Answers
Unfortunately this is main problem of the SDTV - low resolution (believe me or not but I couldn't see where enemy missiles were coming from when I played on my TV). So I switched to my LCD monitor (maybe 17" is a bit small but at least it's 1280x1024).
Posted on Jul 20, 2008
How can I get the F/A -18 Precision Strike Fighter keyboard reference guide
Aileron Left Keypad 4
Aileron Right Keypad 6
Elevator Down Keypad 8
Elevator Up Keypad 5
Rudder Left <
Rudder Center /
Rudder Right >
Increase Thrust =
Decrease Thrust -
Afterburner Backspace
Brake Space
Gear G
Flap F
Hook H
Dump Fuel Shift D
Refuel Shift F
Service (refuel/arm) Shift S
Eject Shift E
Damage Display D
Engine Display E
HUD Options
HUD Altimeter Toggle Ctrl A
HUD Brightness Ctrl B
HUD Clutter Reject Ctrl C
NAVIGATION
Autopilot Toggle A
Autopilot Mode Shift A
Waypoint Cycle W
TACAN Cycle T
ILS Toggle L
Moving Map/Scale M
Nav./HSI Scale N
RADAR
AA/AG Toggle R
Sub-mode Cycle Q
Standby B
IFF Interrogate I
Range Decrease Tab
Range Increase Shift Tab
ACM Cycle Shift R
AACQ Cycle Shift Q
Silent Mode Ctrl R
Radar Target
Designate/Cycle \
Undesignate/TDC Stow Shift \
TDC Up Shift Arrow Up
TDC Down Shift Arrow Down
TDC Left Shift Arrow Left
TDC Right Shift Arrow Right
Radar Scan Volume
Decrease Azimuth Z
Decrease Elevation X
Increase Azimuth Shift Z
Increase Elevation Shift X
WEAPONS
Stores Display S
Cycle AA [
Cycle AG ]
CCIP/Auto Toggle Shift ]
Jettison Station J
Release Flare '
Release Chaff ;
ECM Toggle C
Designate/Release Enter
Electro-Optical
E-O Weapon Cycle O
E-O Target Cycle Ctrl \
HARM
HARM Select U
HARM Target Cycle Ctrl \
SIMULATION
Pause Flight P
Exit Flight Shift Esc
Fast-time Toggle Ctrl F
Warp-time Toggle Ctrl W
Earlier TOD Ctrl E
Later TOD Ctrl L
Night/Day (+6 hr) Ctrl N
Joystick Program Ctrl J
Hide Instruments Ctrl I
RADIO MESSAGING
Ground Control Shift G
Control Tower Shift T
Flight Ops Shift O
Approach Control Shift C
Landing Signal Officer Shift L
WINGMAN COMMANDS
F1: Wingman flies to your 4 o'clock position.
F2: Engage/protect my air target.
F3: Resume your mission objectives.
F4: RTB or Return To Base. I use this only when my wingman is low on fuel (he will call "Bingo" when he has just enough fuel left to return to base).
Tactical pre-merge setup:
F5: "Bracket left" or flies to your left side (9 o'clock).
F6: "Bracket right" or flies to your right side (3 o'clock).
F7: "Split High" or flies at your right at a higher level.
F8: "Split Low" or flies at your left at a lower level.
Admin commands:
F9: Echelon. Parade position at your 4 o'clock.
F10: Trail. At your six o'clock.
F11: Combat spread.
F12: Lead. In front of you.
VIEWS
Cockpit Views
Forward 1
Look Down 2
External View 3
Selected Target 4
My Aircraft 5
Padlock Target 6
Padlock Nearest 7
Padlock Wingman 8
In-flight Weapon Toggle 9
Radar Target Toggle 0
VIEW MODIFIERS
Look Left Arrow Left
Look Up Arrow Up
Look Right Arrow Right
Look Back Arrow Down
Optical Zoom In Home
Optical Zoom Out End
Move Camera In Page Up
Move Camera Out Page Down
Multiplayer Chat Shift '
AA: Air-to-Air
AMRAAM: Advanced Medium-Range Air-to-Air Missile
AS: Air-to-Surface
HARM: High-speed Anti-Radiation Missile
HD: High-Drag
LD: Low-Drag
LGB: Laser Guided Bomb
STORES DESCRIPTION
AIM-9M Sidewinder (190 lbs.) Short-range infrared-guided (heat-seeking) AA missile
AIM-9Mx2 Sidewinder (380 lbs.) Short-range infrared-guided (heat-seeking) AA missile
AIM-120 AMRAAM (350 lbs.) Advanced medium-range radar-guided AA missile
AGM-65B Maverick (645 lbs.) Electro-optically guided AS missile
AGM-88 HARM (790 lbs.) High-speed anti-radiation radar-homing AS missile
AGM-62 Walleye (1250 lbs.) Electro-optically guided gliding AS missile
MK-82 LGB (600 lbs.) Laser-guided general-purpose light bomb
MK-83 LGB (1100 lbs.) Laser-guided general-purpose medium bomb
MK-84 LGB (2100 lbs.) Laser-guided general-purpose heavy bomb
MK-82 LDx2 Slick (1040 lbs.) Free-fall general-purpose low-drag light bomb
MK-83 LDx2 Slick (2130 lbs.) Free-fall general-purpose low-drag medium bomb
MK-84 LD Slick (1980 lbs.) Free-fall general-purpose low-drag heavy bomb
MK-82 HDx2 Snakeye (1160 lbs.) Free-fall general-purpose high-drag light bomb
CBU-59B Cluster (490 lbs.) Free-fall anti-personnel and munitions bomb
B-57 Nuke (650 lbs.) Free-fall tactical thermonuclear bomb
BLU-107B Durandal (483 lbs.) Rocket-powered anti-runway bomb
EXT FUEL (2500 lbs.) Disposable fuel tank
FLIR (350 lbs.) Forward looking infrared pod / Electro-optical targeting device
RECOMMENDED LOADOUTS
Mission Type
Station=>Store
Patrol
1/9=>AIM-9M, 2/8=>(Empty), 3/7=>(Empty), 4/6=>(Empty), 5=>(Empty)
Medium Range CAP (Combat Air Patrol)
1/9=>AIM-9M, 2/8=>AIM-120, 3/7=>(Empty), 4/6=>AIM-120, 5=>EXT FUEL
Short Range CAP (Combat Air Patrol)
1/9=>AIM-9M, 2/8=>AIM-9Mx2, 3/7=>(Empty), 4/6=>AIM-120, 5=>(Empty)
Escort
1/9=>AIM-9M, 2/8=>AGM-88, 3/7=>EXT FUEL, 4/6=>AIM-120, 5=>EXT FUEL
Intercept
1/9=>AIM-9M, 2/8=>AIM-120, 3/7=>EXT FUEL, 4/6=>AIM-120, 5=>(Empty)
Ferry
1/9=>AIM-9M, 2/8=>(Empty), 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
CAS (Close Air Support)
1/9=>AIM-9M, 2/8=>AGM-65B, 3/7=>AGM-88, 4/6=>(Empty), 5=>CBU-59B
SEAD (Suppress Enemy Air Defenses)
1/9=>AIM-9M, 2/8=>AGM-88, 3/7=>AGM-88, 4/6=>AIM-120, 5=>EXT FUEL
Light Free-Fall Strike
1/9=>AIM-9M, 2/8=>MK-82 LDx2, 3/7=>(Empty), 4/6=>(Empty), 5=>EXT FUEL
Heavy Laser-Guided (Precision) Strike
1/9=>AIM-9M, 2/8=>MK-84 LGB, 3/7=>MK-84 LGB, 4/6=>(Empty), 5=>EXT FUEL
Heavy Free-Fall Strike
1/9=>AIM-9M, 2/8=>MK-83 LDx2, 3/7=>MK-83 LDx2, 4/6=>(Empty), 5=>EXT FUEL
Deep Interdiction Strike
1/9=>AIM-9M, 2/8=>MK-84 LGB, 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
Nuclear Strike
1/9=>AIM-9M, 2/8=>B-57, 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
Anti-Runway
1/9=>AIM-9M, 2/8=>MK-82 HDx2, 3/7=>BLU-107B, 4/6=>(Empty), 5=>MK-82 HDx2
Anti-Tank
1/9=>AIM-9M, 2/8=>AGM-65B, 3/7=>AGM-65B, 4/6=>(Empty), 5=>(Empty)
Jan 26, 2012 | Xicat Interactive F/A -18 Precision Strike...
Tip
How To Use A Spotting Scope For Shooting
If you practice hunting and shooting, a spotting scope is one of the best instruments that you need to have to provide you with a clear view when you are aiming at your target. Before we get started on how to use a spotting scope for shooting, it is great if you know what exactly a spotting scope is.
Precisely, a spotting scope is a small device that is used for many outdoor activities to magnify and help you watch images and objects closely. Before purchasing the best spotting scope for shooting, you need to know a few things that will help you use it well in your shooting career. Here are some things that you need to know when using a spotting scope for shooting.
Comfortable Position Is Key
If you want to get the best performance from your spotting scope, ensure that you position yourself in a comfortable place. You know when you are using a spotting scope you will be holding it for long so it is very crucial to find a comfortable place that you can sit or lay down depending on what you find best. Make sure you find a comfortable place and learn more about the specifications of the area which should be the point of targeted area.
Attach Your Scope To A Tripod
Sometimes holding your scope with your hands can compromise the quality of images that you get because of shaking and fatigue. If you want to achieve a clear and accurate view, get a tripod and attach to your scope. This means that your scope will be very stable because there are minimal movements so you end up getting very accurate results. When you are using a tripod, the chances of missing your target are very minimal.
Adjusting The Magnification
You should also adjust the magnification of your spotting scope to a level that you like. Spotting scopes are designed differently so you need to know how to adjust magnification and the lens layout of your scope. For the most accurate results, it is great if you read the instruction given about the magnification levels and how to adjust.
In some spotting scopes, you need to use the lens knob so that you can zoom in and out of the magnification. In other scopes, you need to use the small zoom in and zoom round trigger on the point of the eyepiece.
View Target Area And Adjust Magnification
When you are using spotting scopes, it is not advisable to go with the magnification first because you might not get the right results. The best thing that you can do is to view the target area first and then adjust the magnification effectively.
Reset Focus In A New Area Always
This is very important because a sudden highly magnified glass can cause problems to your eyes. This means you can feel uneasy when you are watching your target longer. This results because of watching at a very high magnification glass for a prolonged period. You can overcome the problem by reducing the effect of the magnify glass on your eyes.
Beating The Sun
If you want to become a spotting scope pro, you must learn how to beat the sun. You need to know how to deal with the frustrating heat waves because they quickly distort your view and it becomes difficult to grass. The best way in which you can beat the sun is to zoom out. Zoom out to a lower power setting and you will enjoy heat-wave glassing hours. You should wait for passing cloud because they reduce the heat wave and give you the chance to zoom back in your target.
Final Words
Buying the best spotting scope for shooting is not enough. You also need to learn how to use it so that you can get clear and bright images all the time. This will help you gain accuracy when you are shooting so no more missed shots. If you learn these tips, you will not experience any problem when you are hunting or shooting. Knowing how to use your scope is the only way in which you will get most out of it when shooting. Best Spotting Scope to buy in 2017 Buying Guide Reviews
on Jul 19, 2017 | Miscellaneous
Tip
Sight in your scope
I have given this tip to a dozen people this week. It will save you a ton of ammo. If you don't have a bore sighter of access to one, get a big cardboard box, cut V's in the top that the rifle will sit in nicely, remove the bolt. Find a target, 100 yards away, sight down the bore, tilt box, rifle to target, make sure it doesn't move, adjust scope to the same target. check to see if the rifle is still on, then check the scope again. This will put you on paper at 100 yards.
on Feb 17, 2010 | Optics
I just purchased this fan from Target. It doesn't turn on. I unscrewed some screws and ...there is no connection from the base to the fan. There seems to be a lot missing from the motor too. My guess is...
More than it's worth by a lot. I would go to target with the target SKU and have them find one at a different store and have it brought in for you. If it is the last one in all the world there is a reason. If you like the look, copy all its model numbers and such take a good picture of it and see if you can find one on the web. The shipping on the fan would be around 50 dollars and hunter would charge you full shop rate and parts as it is not their responsibility but Target's. If you wait too long you will have some trouble returning it, so I would choose your course of action soon. Hunter can help you find who has the model for sale if it's not one made specifically for Target. Good luck, Farmerbear at FixYa.com
Sep 30, 2010 | Hunter (90121) Stand (Pedestal) Fan
I bought a used scope with no manual. On the front of the scope it turns like the back but it has ranges on it do I need to know what range I am shooting for the rifle to be accurite
Take the bolt out of the rifle so you can sight down the barrel to the target. Get the target bullseye in the center of the barrel. Now look through the scope to see where it is. Adjust the windage and elevation screws to get the cross hairs on the bullseye. Look through the barrel several times to make sure the gun did not move off the target during the adjustments. A concrete bench with sandbags is best to use for this.
Dec 05, 2009 | Burris Fullfield II Riflescope
Looking for a ubisoft game manual and not sure if this is a location that will help..not much of a gamer, but need manual for ps2 Heroes of the Pacific game. I looked on the "ubisoft" site but didn't see...
FLIGHT CONTROLS blacklinespacer.gif Steering or Roll: Left analog stick Left/Right Change Pitch of Plane: Left analog stick Up/Down Roll Left/Right/Move Vertical Rudder Left/Right: Right analog stick Left/Right Throttle: Right analog stick Up/Down Engage Warspeed: R3 (click right stick)
blacklinespacer.gif COMBAT CONTROLS blacklinespacer.gif Give Wingmen Order: Attack: Directional Up Give Wingmen Order: Defend: Directional Down Give Wingmen Order: Break: Directional Left Give Wingmen Order:Form Upk: Directional Right Next Target: x.gif Closest Air Target: Hold x.gif Rear View: triangle.gif Cycle Secondary Weapons: square_white.gif Next Objective: circle.gif Closest Objective: Hold circle.gif Target Camera: l2.gif Fire Secondary Weapon: l1.gif Zoom In Gunsights: r2.gif Pause Menu: Start Change View: Select
From http://www.gamesegment.com/PS2/instructions.cfm/id/6386730
Nov 17, 2009 | Video Game Consoles & Games
Copy of instuctions for fighter squadron
Flight and Weapons
Joystick
Button 1 fire main weapon Button 2 fire guns Keyboard
E engine on/off Ctrl P props feather on/off P toggle autopilot + increase throttle - decrease throttle F flaps down Shift F flaps up G landing gear up/down B toggle wheel brakes Ctrl E eject T target Space fire guns 1 select main weapon M.G. 2 select main weapon cannon 3 select main weapon all guns 4 select rockets 5 select bombs 6 select bomb bays A arm master weapon Enter weapons release D toggle bomb bay door Wingman Commands
J as you were K form up on my wing L attack my target ; disengage ' return to base Rudder/Trim
< rudder left > rudder right / rudder center Left Arrow trim left Right Arrow trim right Up Arrow trim up Down Arrow trim down Ctrl Left Arrow rudder trim left Ctrl Right Arrow rudder trim right View Selections
F1 set designation padlock F2 external F3 chase F4 weapon F5 next vehicle Shift F5 previous vehicle F6 command vehicle Shift F6 A.I.-controlled vehicle F7 next crew Shift F7 previous crew F8 tower view F9 quick view 1 F10 quick view 2 F11 quick view 3 F12 quick view 4 M in mission map Shift M in mission map close-up Overlays
H toggle HUD Shift H HUD mode Ctrl H HUD color Shift I HUD intensity up Ctrl I HUD intensity down Alt M target state R target map range Alt W weapons state Alt V vehicle I.D. state Alt I I.D. state Inside Plane Views
Numpad 8 foward Numpad 2 aft(behind) Numpad 4 left Numpad 6 right Numpad 5 up Numpad 0 down Shift Numpad 8 pan up(digital) Shift Numpad 2 pan down(digital) Shift Numpad 4 pan left(digital) Shift Numpad 6 pan right(digital) Ctrl Numpad 7 shift up Ctrl Numpad 1 shift down Ctrl Numpad 4 shift left Ctrl Numpad 6 shift right Ctrl Numpad 8 shift aft Ctrl Numpad 2 shift fore [ zoom in ] zoom out Shift Numpad 5 center your view System
Z screenshot Esc end mission Shift Esc pause game Ctrl Esc end program Ctrl - reduce window Ctrl Equal Sign enlarge window Shift - reduce gamma Shift + increase gamma Network
~ radio chat
Sep 22, 2009 | Activision Fighter Squadron for Windows
Problems with picture quality
if it shows up on multiple games then there is a problem with either your cord or your tv. Trying cleaning the connectors that room from the xbox to the tv. Do you have an old tv or a newer one?
Feb 20, 2009 | Buck Legendary: The Box for Xbox 360
Ace combat 6 flight stick controller
order a new controller or replacement parts of ebay....
Dec 24, 2008 | Namco Ace Combat 6 Flight Bundle: Xbox 360
Namco Ace Combat 2 for PlayStation 1 Logo
183 people viewed this question
Top Namco Video Game Consoles & Games Experts
Jim Goldsmith
Jim Goldsmith
Josh Whitehead
Josh Whitehead
EnergeeUK
Level 1 Expert
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
