Question about Philips Audio Players & Recorders
My Philips GoGear SA51xx keeps turning off out of nowere and i cant turn it back on
  • Anonymous May 15, 2009
    It cut off on me one day and since then i cant turn it back on.
    when i plug it up on the computer it cuts on likes nothings wrong.....and it wont cut on when i unplugg it
Is it 100 percent chared
Posted on Aug 22, 2008
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
Cant get mp3 to turn on
Try holding in the volume + button and reconnecting it to your computer. Continue holding the volume + button in until the "found new hardware" wizard comes on. NOTE: if you hold the volume + in for longer than 1 minute and no hardware wizard appears, this strategy will not work with your version of Windows.
Apr 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Mps3 sa51xx
If you find that the GoGear will not load the firmware upgrade, then:
1) Backup all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the upgrade
Also, if the Philips Device Manager says that your device is already updated with the latest software, then go to: www. usasupport. philips. com,and enter in your model number, SA5125/37, on the next page select SA5125/37 (not "37B"), on the next page click on software and drives, and click on Firmware Upgrade Software - this will ensure that your player really has been given the most current firmware upgrade
-Tha Mp3 Doctor
Mar 24, 2008 | Philips SA5125/37 MP3 Player
Philips GoGear Mp3 player problem
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Jan 04, 2008 | Philips GoGear HDD060 MP3 Player
Memory corruption
My mp3 player Philip SA51xx 2gb says "memory corruption please repair it now" can I ask your hepl to fix the problem thank you
Dec 24, 2007 | Philips SA5125/37 MP3 Player
Philips mp3 play isnt working
-Tha Mp3 Doctor
Dec 09, 2007 | Philips GoGear SA178 MP3 Player
Power
-Tha Mp3 Doctor
Apr 03, 2007 | Philips HDD1630 MP3 Player
1,087 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
