Vulcan oil heater
My heater has been working fine for 40 years but recently when I ignite it fills with smoke, then lets out a bang and ignites. There is also a oil smell. Any thoughts. The heater is cleaned every year.
Thanks
  • Anonymous Oct 06, 2008
    same here. careful tho now mine doesnt work =(
Pnutgllry
  • 57 Answers
SOURCE: toyo laser 30 smokes and smell like unburned fuel when it ignites
If you just changed gaskets on your heater it is normal for it smoke a little bit when you first restart it. It should go away after a while though. If you smell unburned fuel you have a leak somewhere, or a spill. Check all your fuel line connections in the house. The back of the heater where the line connects, the firestop valve (the valve behind the pump that opens or closes the flow of fuel), and any connections in there behind the pump/fuel resevior. (sp) Check that they are tight. What has also happened to me is fuel has spilt and ended up along the back edge of the stove. you might be able to be crafty and unscrew all the screws at the bottom, to try to clean that up. It doesn't take much of a spill to create a very pungeant diesel smell.
Posted on Dec 09, 2008
tbugger
  • 232 Answers
SOURCE: Reddy heater 150,
Set the pump pressure!
Posted on Dec 13, 2008
steve_lima
  • 181 Answers
SOURCE: heater will not ignite checked lines but heater
what is yor air pressure?have you checked you rotor to see if it is broken.all pro's are note for that.
Posted on Feb 24, 2009
  • 53 Answers
SOURCE: Vulcan Ilec central heater main burners turn off after few second
Flame rollout sensors, overheat thermistor, air proving switch, bad earthing, blocked flue. Any of these things can cause your problem. If its a permanent pilot, is it clean burning?? If electronic ignition, is the flame rod clean i.e. no carbon or rust etc.. Safest bet is a qualified gasfitter take a look at it.
Posted on Jul 19, 2009
johnsonr1
  • 91 Answers
SOURCE: old vulcan heater pilot light on but will not
I believe that model has a milivolt pilot generator. The possible causes of your problem could be a dirty pilot generator preventing it from providing the proper voltage to the gas valve or a defective gas valve. If you have a digital multimeter that will read mili volts, you can check the out put of the pilot by placing the leads on the two wires at the gas valve and reading the voltage. It should be 500-750 mili-volts. One other possibility could be one of the safeties have opened. They will be little button type snap disc limits with a button on the top. They will have a wire connected to each side. Push the button, if you hear a click, that safety has tripped. If you provide the exact model number I can post an exploded view for your use.
Posted on Sep 17, 2009
Hi We recently bought a house that has an 40 series Vulcan oil heater in it. Can anyone tell me how to light it. It has a knob on top with numbers from 1 - 5 (2 being ignite). A lever on the bottom that...
Make sure the tank outside has oil ( Kerosene) in it. Check the fuel tap (under the tank) is turned on. When you press and hold the heat control button, it should ignite after a few minutes. The lever on the bottom is the fan control switch (high speed or low speed fan) Make sure that the unit is plugged into the power. If I remember correctly, a red light appears to say it is powered up on the bottom left hand side.
Jun 19, 2014 | Heating & Cooling
Vulcan oil heater how to remove heating element
Burner pot needs to be removed from heater, for hearers of this vintage, Best advice is to have the burner pot and heater serviced and replace ignition element at same time, I can do this,live in Adelaide. Probably cost $250 inc parts, test run, calibrate.
May 17, 2012 | Vulcan Heating & Cooling
Just installed a vulcan oil heater, but when you start it up it will only burn yellow flames and keeps going out and will smoke, then relight with a bang,
Sounds like you may have the wrong size tip on your oil burner. A yellow flame indicates too much fuel not enough oxygen.
Jun 08, 2011 | Heating & Cooling
Can't seem to ignite pilot on a 30 year old vulcan heater. Same problem every year as winter is approaching :) Usually works fine once pilot is on though.
It's probably just a dirty pilot orifice (or a spider web), if it's been off since last winter. Try using a can of compressed air with attached straw (like you use to clean computer keyboards) and blow out the dust from the pilot orifice in the pilot assembly, which is where you light it. That should do the trick. Good luck! Douglas
Jun 07, 2010 | Heating & Cooling
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Hi my vulcan gas wall heater goes 'bang' after a few minutes of operation. It sounds like a gas explosion but I can't detect any leak.
it sounds like delayed ignition, this is VERY dangerous, you need to verify sequence of operation and fuel air mixture.
Jul 07, 2009 | Dakota LY43 Ceramic Compact Heater
Vulcan Oil Heater not operating correctly
If the red light comes on when starting, this means that there is continuity in both exhaust heating and igniting elements and the heater cutout is also working.
The most common problems with this heater is coke & soot build up in the bottom oiltray and clogging the bottom air intake holes, to remove this the heater box has to be dismantled.
Jun 16, 2009 | Heating & Cooling
Blows big puff of smoke on start up.
I have a all pro modelspc k100 will not ignite when pluged in
Jan 20, 2009 | Dayton E51 Oil Filled Utility Heater
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
