Question about Mitsubishi HS-U560 VHS VCR
A tape is stuck in my VCR. and i cant get it out, How can I remove it? notheng
    Novelist:
    Champion:
  • 275 Answers
Open bottom metal cover. Rotate the belts of the motor. Cassete should unload from Spindle and reel back into the cassette. Then please open the VCR top, and you will see a belt and gearmechanism on the right side of the cassette compartment. Manually rotate the gears and the tape will slowly come out.
Posted on Jul 20, 2008
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
Feb 27, 2014 | Mitsubishi Televison & Video
Tape is stuck, can't remove it
I remove a stuck tape from a VCR by taking off the outside cover. (My unit was held together by 5 screws.) This allowed me to access the tape and check where it was locked. I had to loosen a twisted tape from the mechanism and then I could eject it. (Note: I unplugged the deck before removing the cover.)
I hope this helps.
(I've been fortunate; I've only had to do this on VCR units (not VCR/DVD) that were out of warranty. If your MWR20V6 is still in warranty, you may not want to open the case at home.)
Dec 17, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Had a stuck tape its gone now but still having trouble.
The tape is stuck in the vcr and doesn't get released. How can I remove it?
Aug 15, 2009 | Emerson EWV601 S-VHS VCR
GE vcr tape stuck
when this happens to me, i disconnect the vcr and remove the screws to the top cover. i remove the cover and carefully remove the tape, being careful not to touch any of the parts of the vcr. but please make sure the vcr is un plugged.
Dec 08, 2008 | GE VG4052 VCR
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
DMR-EZ47VK Up-Converting 1080p DVD-Recorder/VCR Combo
I think the problem with the tapes stopping is that there is too much tension on the tape. Try another VCR and try to see if you have the same problem playing the tape. Forward and reverse through the part that causes the player to stop. It is also possible that the tape inside the vcr has become twisted or stuck. One can fix this if they are very careful opening the video tape. However, I would not recommend this for most people
Mike
Dec 22, 2007 | Lite On LVW-5045 DVD Recorder
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Televison & Video Logo
258 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
