Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Computer monitor screen remains black
When I turn on my computer, everything comes on, the light showing the monitor is on, but the screen remains black. I tried shining a light on the screen, and you could just barely make out that it was running, just not bright enough to see the display. Is there a fix for this, or is it shot? It is only 4 years old.
  • 1 more comment
  • Anonymous Aug 11, 2008
    wheni turno n my hp pavillion all the power buttons work but my screen is black
  • Anonymous Sep 03, 2008
    same problem where CPU starts up and screen comes on normally then blacks out in a 1 to 2 seconds.
    Tried unplugging and plugging the power quickly as I scrolled thru the menus. Have not figured that one out why even after going thru all the monitor menus (even reset back to default settings)??
    Shine a very bright flashlight on the screen to read the menus but still did not help. It is like a power save feature is turned on after a 1 second delay?
    Patience wearing thin
  • CandX Sep 04, 2008
    Same problem with my HP Pavilion F1503 flat screen: it became very dark suddenlty and nothing is visible on the screen. If I shed some light on the screen, you can see that the display is normal. It is like a back light is missing. I unplugged and replugged everything, even plugged the screen to another computer. Same result. Help!
Try giving the monitor a hot slap or spank at the back, believe me, you'll be surprise, you've got nothing to loose
Posted on Sep 06, 2008
Should I replace Monitor?
Your monitor is telling you that it is time for you to replace it. Your monitor is going bad on you and will only get worse.
Mar 26, 2012 | Computers & Internet
Will not come on...green light blinks showing power, but screen remains black...have tried all resets, hooked up different computers to it etc...
It's possibly the cable/plug points. I leave the vga plug unscrewed so that the computer is easy to move around and I sometimes have problems with the screen not coming on. Try a different cable.
Mar 09, 2010 | Samsung SyncMaster 244T 24" LCD Monitor
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
Acer P221W 20in blacking out
check your graphics card wait 20 minutes or more see what comes up i recently had that or if u try everything eg replacing everything and it still don t work try rebooting the computer with the recovery disc which means it will wipe out everything programs everything.
Sep 28, 2008 | Acer Professional P211 21" CRT Monitor
Screen remains black and flashing blue light on power button
I also have the exact same problem. My monitors been collecting dust for a while now and I can't find the solution anywhere.
Aug 05, 2008 | HP f1905 19" Flat Panel LCD Monitor
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Feb 15, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
My monitor will not turn on
Test it with another monitor to see if all is well and if you see things then there is a problem with the LCD.  Come back here for more instructions.
Oct 15, 2007 | Acer Aspire 5100 Notebook
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
187 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
