Question about Admiral Refrigerators
I have an Admiral Side by Side refrigerator. The ice maker is not working properly. This has been an on going problem. Sometime, it works just fine without any warning it just slows up and start making only a few cubes during the course of a day, not even enough to fill the tray. The water inlet valve was just repalced. Even when it is working at it's best, it still takes a while for it to fill the tray. Is there a setting to control the amount of out put?
  • John Sanders Jul 20, 2008
    As previously stated the water inlet valve was just replaced. When it does make ice the ice is solid.
  • John Sanders Jul 25, 2008
    Well my questions are:
    1. What is it suppose to be doing in order for it to be making the Ice?
    2. What do I have to do to resolve the problem?
    There is a NEW water inlet valve already installed.
    Please forward relply to sandborn45@hotmail.com
    Thank you,
    John
    Master:
  • 726 Answers
Yes there will be a problem with the internal motor
not doing what is supposed to
its seems like its trying but lacking in power to produce
Posted on Jul 20, 2008
    Genius:
  • 1,665 Answers
When your ice maker produces small or hollow cubes, it's a sign the unit isn't getting enough water. The cause could be a faulty thermostat or a bad water-inlet valve--problems you may want a professional to fix.
Or if you're lucky, you may just have a clog in the water-supply system.
See "HOW ICE MAKERS WORK " at link below
http://www.repairclinic.com/0088_1_3.asp#Level1_1
My Admiral LSD2615HEZ freezer is icing up? The freezer temperature setting is set between 4 & 5 and the water dispenser and ice maker are working properly. What might be the cause and what are the...
Check the water pan underneath, dump if necessary. Clean up any dust, etc. Reset to normal temp and do not open door for 24 hrs. If this doe not work check compressor / condensor
Aug 13, 2013 | Admiral 26 cu. ft. Side-By-Side...
Admiral Maytag side by side model LSD2615HEW not getting cold. Fan runs. Clicks from the back every few minutes or so.
Its issue with compressor or the problem with defrost timer.It clicking to set the defrost cycle,but not actually working.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fjkfjf
Aug 07, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker not working .making noise but ice not dropnig
heatman101
ys452
My ice maker has stopped working, the water dispenser still works.
heatman101
klggkllk
Jan 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker stoped
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Apr 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker has stopped working. It was fine 3 days
check water valve or icemaker valve is at the back of the unit
Apr 07, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Apr 12, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
