Question about JVC KD-G320 CD Player
Wont keep memory
Is there any way to find a 2 way wiring diagram for a 92 cougar and a jvc KD-G20? One that will show me exactly what wires go where. pretty sure theyre crossed somewhere. Need to know which wire to run to fusebox for the memory.
  • mgnapp Jan 12, 2009
    I have an 88 Olds Delta 88 and am replacing a Clarion DB315 with a JVC AR390.  The Clarion was rigged in a way that every time I turn the car off I would lose all my settings and what a pain to reset everytime I turn the car back on.  I knew it was the 12v constant wire but just thought I would wait until I replace the unit to fix it.  Now I am finding the orange 12v constant wire in my car seems to be dead when connected to the yellow wire on the JVC thus explaining the reason for the rigged job on the Clarion.  All fuses are good, but my fear is I may have to pull the entire dash to look at the actual connection.  Is there an easier solution?  Thanks!
  • 1,586 Answers
Most stereo manufacturers agreed on a color-coding scheme for their wiring to keep things consistent. In that scheme, red wires are run to power (ie, the battery) and serve as the ignition-switched power leads (so when the engine is shut off, the head unit also shuts off), black wires are grounds, and purple, gray, green, and white are used for the main four speakers. Blue is an antenna and/or amplifier turn-on wire. Orange is a dimmer wire (for cars with dimmers on the dash lights, this can be tapped in to also dim the head unit's lighting). Yellow wires are typically the memory wires. These feed power to the head unit constantly, regardless of whether the car is on or not, so that memory presets and tone settings are maintained. Your JVC unit should have a yellow wire coming off the back as part of the harness - this would be the one to supply power. You can run this directly to the battery - that way if you blow the fuse in the fuse box that you're considering using, you won't lose your stereo settings as well as whatever feature the fuse was utilized to protect.
Posted on Jul 23, 2008
Dont use the car harness ground wire.... ground the radio directly to the body of the car and your problem will be gone :)......
Posted on Jul 14, 2011
What color is the memory wire on the jvc kd 960bts
http://pdf.crutchfieldonline.com/ImageBank/v20141216141900/Manuals/105/105KDR860B.PDF
The yellow is the permanent live (memory) wire, red to ignition and black to ground.
Check the link above, page 31 for the wiring diagram.
May 16, 2016 | JVC Car Audio & Video
How can i save my settings on jvc kd-r446 ? every time i shut down my settings is reset
if it is resetting oon shut down , you dont have your memory wire connected to a full time power wire . full time power wire is a wire that has power even when car is off.. this is what saves your memory on the head unit.memory wire is usually yellow.
Feb 26, 2014 | JVC Car Audio & Video
Jvc Manuals
The wiring diagram is on the last page of the manual at http://www.jvc.co.nz/assets/pdf-manual/KD-R526.pdf
May 15, 2013 | Car Audio & Video
92 nissan pathfinder radio
need a diagram of wires. can buy manual of go to local auto zone and they may be able to print you out one at no cost...good luck
Aug 13, 2012 | 1992 Nissan Pathfinder
I need a wiring diagram for a JVC KD-AR800
here is the link to download the manual, it explains how to set the clock
http://www.retrevo.com/support/JVC-KD-AR800UC-Car-Receivers-manual/id/989bh839/t/2/
Apr 04, 2010 | JVC Arsenal KD-AR800 CD Player
Where can i find a wiring diagram for my jvc
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Oct 02, 2009 | JVC Car Audio & Video
Need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Aug 16, 2009 | Car Audio & Video
JVC KD-G320 CD Player Logo
1,268 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
