Question about HP Pavilion dv1000 Notebook
Hp laptop when you turn it on it says windows did not start successfully then gives options safe mode, safe mode w/network, last known config. an start windows normal. it doesnt matter wich one you choose it does the same thing after you pick an option it goes to the windows logo like its booting up then it starts all over w/ the safe mode screen
  • 31 Answers
Windows is thnking that you have a problem with the system
start windows in safe mode and troubleshoot and see what the problem is if all else fails you might have to to a system restore
or take it into a tech and see what they think
hope this helps
cheers
Posted on Jul 20, 2008
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Laptop wont boot it comes up with page saying windows did not start successfully then gives option to start windows normally, in safe mode, safe mode with networking, safe mode with command prompt or...
Windows is corrupted beyond repair, you will have to reinstall it and return the laptop to factory condition. Use the recovery disk that came with the laptop when you bought it an follow the instructions from the manual to the letter.
Dec 20, 2010 | Computers & Internet
My compaq mini notebook wont boot up, when you switch it on it comes to a page saying windows did not start successfully. A recent hardware or software change may have caused this. It then gives you the...
Hi, sounds to me that you are having a software problem. When you boot the laptop choose the Last know good configuration option to see if that will correct the problem.
Dec 20, 2010 | Compaq Computers & Internet
I have an LG LS50-EYYE1.It is not starting successfully. The screen says start windows normally.The screen Safe mode, Safe mode with networking, Safe Mode with command prompt,Last known good config. None...
Just try to repair your Windows , that will solve the problem . If you don't know how to repair it , just contact me again and i'll help you as possible as i can .
good luck .
Jan 28, 2010 | Computers & Internet
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
How do you access the boot list on my compaq armada 1750
Tap the F8 Key as soon as the Laptop is powered on, keep tapping it till it brings you to Boot Choice Menu Options.. Options such as: Safe Mode, Safe Mode w/ Networking, Last Known Good Config..etc... are listed here..
Press and hold the F12 Key If You Need To Get To Boot Choices.. Such As Boot From CDrom, Boot From LAN, Boot From USB Device..
Nov 17, 2009 | Compaq Armada 1750 Notebook
My computer froze during shut down, so I turned it off using the power button. When I start it up It gives me the options of starting normally, Last known good configuration, safe mode safe mode with...
Try go into BIOS by hitting the DEL key or F1 or F2 as you start and go to save Cmos config. then reboot.
The other approach is Last known Good config is the best. This can be brought up after presing power button then by tapping F8 till screen apears.. Select Last known Good Config
Nov 08, 2009 | Sony VAIO VGC-RA840G PC Desktop
HP Pavilion laptop restarts during welcome screen
Do the power drain
step1. Remove battery and ac adapter
step2. Hold on to power switch for 30secs-1mint
step3. Put back the battery and ac adapter
step4. Start the laptop as usual
IT SUD BOOT PERFECTLY
after doing this also if the symptoms are same
i apologise to tell u ...its gonna be Motherboard probs which is common nowadays in Most of the HP LAPTOP
Feb 21, 2009 | HP Pavilion dv6000z Notebook
Laptop wont start
Dear customer
your system OS is corrupted.so please installed oprating system newly XP or VISTA.try this
Jul 25, 2008 | HP Pavilion ze4145 Notebook
Windows did not start successfully.
hi asharah,
Ur operatibg system was corrupted ,u reinstall the operating system (xp ) .
Pl try it
Regards
Was this soultion useful? give the appericiation by rating it.
Mar 27, 2008 | Acer TravelMate 2300 Notebook
HP Pavilion dv1000 Notebook Logo
109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
