Use an Ethernet cable to connect the network port on a computer (desktop/laptop/notebook) to one of the LAN ports on the router.
Start your computer's web-browser, and connect to the web-server "inside" the router.
Run the "Wireless Network Setup Wizard" to configure your wireless network, i.e., pick an SSID and a password.
Then, configure your telephone to connect to that SSID, and to use the password that you selected.
Hi sos1309, you can't do that. You need to get a VoIP router and hence an Voip service. Were you looking to use your phone for anything in particular?. I hope this helps. Please dont forget to rate and provide positive
feedback for our free support today. Thank you :D
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
1) With direct connect with modem, check the IP address and default gateway. (I came across such a modem, it gave default gateway as 192.168.1.254) I also had the doubt of configuring as a dynamic connection But it won't work! Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password. Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Hi, since your Internet source is the ISP modem, you have to connect the cable from it to the yellow connector of Belkin router, then you can connect the VoIP router and computer to any of the ports (connectors) labeled 1-4 , remember to restart clients (PC & VoIP router) to get the new IP from Belkin router.
Unless you have dial up, you arent supposed to be losing any connection between the two. If you are, i would call them up and have them come out to fix it for free. That is completely rediculous.
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
