Philips 55PP8620/79 Rear Projection. Blue convergence has suddenly gone badly out of alignment and wont adjust. This was apparent after tv finally came on after two evenings of tv just 'hick-upping' at switch on.Regards Brad.
  • 8 more comments
  • baradda Jul 22, 2008
    I replaced both convergence chips as suggested by your team, but unfortunately, the fault is still there. The blue cross flashes when trying to adjust,but does not actually move. I am thinking there is maybe a fusible resistor in the blue convergence circuit that is maybe o/c?? I look forward to your advice. Regards
    Thank you once again.However,as I explained previously, I have replaced both STK392-120 chips and unfortunately with no positive results.Regards
    I have found and replaced 2x 0.68r (3149 & 3150).Blue conv is now way way out,however,
    does adjust.Problem now is, chips get extremely hot,and I am sure, will blow if I leave TV running. Could I have damaged chips by not replacing the fusibles at the same time as the chips?? or else TV still has s/c in conv supply line? Regards
    Dan, there is 0.15vac on pin4 and 0.35vac on pin5. Is this too high?
    Okay. Looks like I am at a point where I need a service manual. Can anyone assist me here. Regards
  • baradda Jul 23, 2008
    safemanuals.com only seem to supply 'user guide' and owner/instruction manuals, not service/schematic diagrams. Regards
    Thank you Battlesmith, but the link you provided only gives access to user-guide-instructions-manual. NOT Service Manual-Schematics. I already have the original owners/operators manuals. It is service manual/schematics I require.
    Best regards
    Thank you likha, but unfortunately www.eserviceinfo,com does not have a listing on philips 55pp8620/79 rear view. Also previous pdf of convergence pcb that your team member posted to me was of a totally different philips model. regards
    Thank you Votit for your info. Unfortunately the PDF you sent, high-lighting various resistors, is a totally different pcb to the one used in 55pp8620/79. Regards
  • baradda Jul 24, 2008
    All of the information given by your team members was very helpful and subsequently contributed to the successfull repair of my Philips rear view TV. Thank you all for your invaluable assistance. Regards Brad.
  • 2,334 Answers
Here you will see the voltages you should be getting on the convergence ICs.
Posted on Jul 24, 2008
  • Jaime Hernandez Jul 24, 2008
    I forgot to mention that all the voltages are DC and not AC.
  • 813 Answers
Call the compnay service man have to apply thermal grease to the new ICs. Remember the black coloured compound while replacing the IC? You will have to purchase it and apply it to the new ICs. You can buy it at any major electrical store or you can also purchase it online.. Let me know if you need more help.
    Genius:
  • 2,035 Answers
Try this link for the service manual :
http://servicemanuals.vstore.ca/
  • 4,472 Answers
Https://www.manualsparadise.com/ShowProductsForModel.do?model=M37473762
You can go there to get the service manual for your television.
That should get you all the information that your looking for.
Enjoy,
Lee
Posted on Jul 23, 2008
  • Lee A.
    Lee A. Jul 24, 2008
    If you have a moment and havent done so already I hope you will accept and rate a solution accordingly. What was it that fixed the problem?
    Thanks,
    Lee
  • 790 Answers
Hi
You need schematic for this model just click this.. http://www.eserviceinfo.com
Thanks!
    Genius:
  • 1,226 Answers
Please try to search it here:
http://www.datasheet4u.com/?gclid=CKCwseHq1JQCFRw2egodigkmew
melnavz
  • Emelio Navaja
    Emelio Navaja Jul 23, 2008
    You have to test the capacitor and the resistor in the circuit board. if not finad any fault then maybe suggested to bring the TV to the expert to check it personally (Philips service center in your ARea) and take what is there opinion.
    thank yo for using fixya.
    melnavz
  • Emelio Navaja
    Emelio Navaja Jul 25, 2008
    thank you for using fixya.
    Novelist:
  • 183 Answers
  • 4,234 Answers
Your assumption is correct. With the convergence Ics replaced, normal operation should have been restored. These sets may use low valued resistors rather than pico fuses inline with the power supply lines for the convergence ICs. Check all of the resistors in the area of the convergence ICs. They should test close to their ratings. You may find a resistor open. Please note that these are usually flameproof resistors that will not appear to be faulty. Look for anything tied to pins 4 or 5 of either IC.
Keep us posted on your progress.
Posted on Jul 22, 2008
  • 2 more comments
  • ABRsvcs Jul 22, 2008
    I'm ging to guess that the resistors that were open were for the pins I listed. These ICs need to have the compound behind them. Usually it is white though not black. If there is no compound between them and the heatsink, they will get hot quickly. These will get warm anyway , but should not he HOT to the touch. Can you check the voltage on pins 4 and 5 to ground using an AC voltmeter? There should be no AC on those pins.
    Thanks,
    Dan
    I'd say that there is a lot more ripple there than there should be. Perhaps a glance at the power supply module is in order. Look for hte filter caps for those supply lines. I would have expected less than .1VAC total for either line. I don't have the service manual for your model, so I need to provide generic guidelines here, but I think you are on the right track.
    Dan
  • ABRsvcs Jul 23, 2008
    I have the service manual coming to me. Stay tuned. We'll find this yet!!
    Dan
  • ABRsvcs Jul 24, 2008
    Thanks for the update. Could you post the resultant fix so others that view this can learn? Every situation is diferent and the final fix could be helpful for others.
    Thanks,
    Dan
  • 19,396 Answers
After you replace the ICs, you need to do convergence setup procedure again, ensure you did this.
If you did setup procedure already, check that the pico fuses at the base of the ICs had not blown, if they had blown again, then there is an overvoltage problem, in this case replace whole convergence board or locate the fault.
  • 2,071 Answers
Philips service trouble;
Unit has poor focus Register in service mode set wrong (06-25-96 Menu). Cure: Change Register 026 from 1F to 26, the electrical focus may need to be reset after the change to get the best focus. If electrical focus is reset it only needs to be reset on one mode. Reg 026 however has to be changed in all 6 modes. See Below for the modes VGA – VIDEO – NTSC (640x480) VGA – PC (640x480) SVGA – VIDEO (600x800) SVGA –PC (600x800) HD –VIDEO (1920x1080) HD- PC (1920x1080)
Posted on Jul 20, 2008
  • 2 more comments
  • LORETO LACARON
    LORETO LACARON Jul 22, 2008
    Click below for picture guide a do-it-yourself guide;
    http://www.repairfaq.org/sam/tvfaq.htm#t...
    or
    http://home.earthlink.net/~oleg.filippov...
    or
    http://cmpalmer.blogspot.com/2006/11/fix...
    or
    www.tv.manualsonline.com
    PHILIPS Magnavox service trouble;
    Convergence CONVERGENCE DISTORTION 1. CHECK CONNECTOR "VD" FOR
    PROPER CONNECTION, BETWEEN THE CONVERGENCE PCB AND POWER PCB.
    Convergence BLUE BOW ON LEFT & RIGHT 1. CONVERGENCE WILL
    NOT ADJUST PROPERLY.CHECK FOR LEAKY OR SHORTED Q8F04 PART # 260P651010 AND
    Q8F06 PART # 260P652010. LOCATED ON THE SIGNAL-PCB. 2. CHECK D8F00 AND D8F01
    FOR LEAKAGE IN THE 24/34 V SWITCH CIRCUITS ON THE SIGNAL PCB PART # 264P045040
    3. C
    Convergence DOESN'T RETAIN CONVERGENCE SETTINGS 1. RESET THE
    CONVERGENCE EEPROM, PRESS "MENU 2259" TO ENTER THE CONVERGENCE MENU
    THEN PRESS "8970"
  • LORETO LACARON
    LORETO LACARON Jul 23, 2008
    Click this site,for free download you must register and get free schematic ;
    Then you'll need adobe reader to
    open the pdf
    http://www.adobe.com/products/acrobat/re...
    http://www.win-rar.com/downloadnow.html
    (RUN WIN-RAR AS A TRIAL)
  • LORETO LACARON
    Overheating is caused by the change value of the resistor ,there are 26 resistor all in all.Check all the resistor associated to the pins of the two convergence STK IC and also change the two big filter capacitor it is automatically defected , because of defected STK ,change it with identical rating. Also can cause overheating of STK is lack of silicon compound applied at the back of STK chip,also check this out.Below is the picture of all resistor are placed and the two big capacitor.Just click....
    http://i114.photobucket.com/albums/n248/...
  • LORETO LACARON
    Yes it is a totally different
    PCB to the one used in 55pp8620/79, i agree with that,it is a sample of
    Panasonic PT53WX52.But the principle of function is desame because they are
    using desame STK IC ,only the placement of resistor are very different...i have
    shematic diagram below just copy paste....
    http://www.server382.com/download/Philip...
    Genius:
  • 1,665 Answers
Convergence problems are generally simple repairs, presuming you know how to solder and have a bit of brains about you. STKs are usually at fault (STK392-010/020/040, STK392-110/120/150/180, etc) and are easily aquired and replaced. Sometimes a fusible resistor is taken out in power supply circuit, sometimes a resistor will burn.
  • 4,889 Answers
You have a convergence IC problem. Its gone bad and needs to be replaced. I have uploaded some pics and a how to guide about this problem. Use it to fix the problem. The convergence IC will be numbered something like STK--------.
Here are the pics..
Here is the how to guide..
  • eagle338
    eagle338 Jul 22, 2008
    You have to apply thermal grease to the new ICs. Remember the black coloured compound while replacing the IC? You will have to purchase it and apply it to the new ICs. You can buy it at any major electrical store or you can also purchase it online.. Let me know if you need more help..
    Master:
  • 382 Answers
The Blue convergence error is primarly due to power overflow..So please make sure that you check the circuit board once before concluding anything ,check for any leak of transistors or any Short circuits..If your not Sure for Yourself please call a Service person!..Im very sure it is not a Complex error ,so please dont worry my friend!..For Your further help I have added this manual here ..Please check this out for further details
http://safemanuals.com/user-guide-instructions-owner-manual/PHILIPS/55PP8620-79-_E
Hope This helps you!..Please reply back for how things turned or for further help..THank you!!..
Regards!!..
  • 5 more comments
  • Natesan Sabesan
    Natesan Sabesan Jul 22, 2008
    Hello baradda,
    Yeah i will suggest you to go through the board of your Tv because there is a possiblity of short-circuit of two IC's or probably a IC might have burnt in the Blue convergence circuit area my friend..So kindly find it and replace it which will surely get you out of the problem!..Thank you..
    Regards!..
  • Natesan Sabesan
    IF so then i will kindly advice you check the entire circuit board of ur TV if you find any Short-circuit please rectify it or else you must try to service you Tv in any of the nearest Service showrooms because only a Short-circuited IC or Resistor can cause Blue covergence or the reason must be a Fault circuit board which you must replace so!..Thank you..
    Regards!!..
  • Natesan Sabesan
    I have given the link for service manual before which i give you again
    http://safemanuals.com/user-guide-instru...
    Hope this solves your problem Completely friend!..Thank you..
    Regards!!..
  • Natesan Sabesan
    Natesan Sabesan Jul 23, 2008
    Hello Brad,
    Yeah i know service manual can be of some help to you but all the while i could jus find only the user manual for free in net which is the only available best option I provided you my friend..Sorry about that..Thank you!!..
    Hope my solution helped you with something.. :)
  • Natesan Sabesan
    Yeah Thats wat i told you brad..Only User manual could be found free for Philips 55PP8620/79..The service manual is not available as far i can say my friend..May be you can enquire with any of your friends who has the same model TV from whom you can get the service manual..Thank you
    Best Regards!!..
  • Natesan Sabesan
    "THE BEST FINAL SOLUTION"..
    Please take you TV to any phillips or any other legitimate Tv service outlet in order to solve your problem..Also please dont forget to get a copy of Service Manual for you TV...
    Regards!!...
  • Natesan Sabesan
    Natesan Sabesan Jul 24, 2008
    Yeah Try the Final Solution prescribed which i have already posted because I hope we have reached the situation where only a direct inspection by a Service Person can help you Better!..Thank you !!
    Regards!!!!...
  • 2,427 Answers
It seems as if you have some experience in this field, so i am providing you with the service manual, this will allow you to diagnoise and repair anything that's wrong with the tv
http://www.manuals-in-pdf.com/plist-24-1465.html
or
http://www.philips.user-manuals.com/list-of-manuals-120-2033.html
I have a philips projection TV and it looks like a 3D screen without the 3D glasses. I tried converging the red & it is aligned with the cross hair. The blue convergence does not move. What can the...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2011 | Philips Magnavox 51MP392H Rear Projection...
My 50 in Phillips rear projection has a bad green tint and switches to a bad red tint what can I do?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
60 inch maganavox rear projection tv blue color almost gone if it is a bulb where can I buy one
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
Colors dont align
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue convergence wont work
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Sep 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Wheni turn on my tv ive got a blue outline on what ever i whatch
The blue outline is a convergence problem. Depending on the brand of tv you have there are adjustments to fix that. If the adjustments wont work then the convergence circuit will have to be repaired.
May 04, 2009 | Philips 55PW9363 55" Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
Picture gone.
You have bad conv. ic's.On these sets when the ic's go bad it will usually pop a fuse or burn up a few safety resistors,causing ith video to go away.
Mar 03, 2008 | Toshiba 50H72 50" Rear Projection...
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Televison & Video Logo
500 people viewed this question
Top Televison & Video Experts
