I'm wondering if I can replace the rca inputs and coax jack on a sharp tv
  • 927 Answers
Good day, jscivally;
You bet you can. First determine what coax jack is attached to, eg. tuner, pc board and etc. Then make sure that item was not also damaged. Present model information and it should not be hard to fine the items you need. Make sure you have a good soldering gun, station, this will be soldered on-in parts.
Hope this was helpful, good luck, big IRISH.
Posted on Jul 20, 2008
How do I hook up a dvd player to a sansui tvm1915c when my dvd player has only rca outlets and the tv only has one coax outlet?
Coax to RCA? Not possible considering coax cable provides sound and audio and RCA jacks split them as 3 different outputs. The only way to Solve this would be to get a converter not adaptor. You're gonna have to convert coax signal into digital. You may be able to get away with a converter for the digital antennas they have now that your tv requires to get local channels. Perhaps if you can go red white and yellow RCA into the converter then coax out to the tv or something around those lines, however between me and you it will cost the exact same to buy a converter as it will to buy a 5 dollar TV on Craigslist that already has these settings and inputs built into the TV. People feel bad for throwing out a tv that still works, but it's very common, maybe even for free off craiglist . Good luck!
Feb 01, 2015 | Redi Shade SANSUI Replacement Remote...
U-verse will not show on guide plus rca
its not always going to be channel 3, it depends on the input cable you are using, if you are using an HDMI cable you need to switch to the hdmi input, same with component, and if you are using RCA cables it will probably be called video. Try your other inputs dont just stop at channel 3. If you are using coax and its supposed to be on channel 3, make sure you are on the correct coax jack on the receiver, make sure its the "to tv" jack not the "to wall" jack.
Apr 14, 2013 | AT&T UVerse
I am trying to add a sound bar to this model tv any suggestions as to a compatible one?
The Philips 32PFL3504D TV has several audio outputs that are are compatible with sound bars. You want to be looking for a sound bar with a Digital Coax audio input.
For example:
A Digital Coax audio input looks like an RCA jack and is usually colored orange.
Mar 06, 2011 | Philips 32PFL3504D 32 in. LCD TV
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
Where is the cable connection on my tv
There are usually two types of cables that connect to your tv-- coax and RCA. Cable usually uses the coax style, but some modern tvs don't have a coaxial input, which means they probably have RCA jacks. Therefore, you will probably have to find an RF modulator or the like that has a coax cable "Cable" input and RCA (yellow, white, and red plugs) output. These should be able to connect your tv to cable. I hope this helps, and good luck! Sincerely, Der Strom
Apr 09, 2010 | Protron PLTV-32 Television
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
No sound
Steve make sure that the coax is connected to the output on the DVD/VCR and to the TV's cable or antenna input. This should give you picture and sound on CH 3. If you use RCA jacks you must also use the yellow video plug as well on the same input on the TV as well as on the DVD to get both picture and sound to the tv. The place yoou put the RCA's on the TV will determine where the image will be displayed e.g. if connected to VIDEO 1 on TV YOU MUST CHANGE THE TV TO THE INPUT NAMED AUDIO 1. You can do this by using the input or source button on the remote control for the tv or go into the tv's menu and perform the task that way. I hope this helps you resolve the issue. Thanks for using Fix Ya and let me know if I can be of more assistance.
Oct 15, 2008 | RCA DRC8295N DVD Recorder/VCR
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
Installing DVD player/RF Modulator with Star Choice
The RF modulator probably had a red, white, yellow trio of RCA jacks (A/V jacks), a coax jack marked "antenna" and another coax jack marked "TV"
Putting the DVD output to the A/V jacks allowed it to play out to the TV, which couldn't otherwise accept the DVD player.
The satellite box probably has coax and a/v jacks as output. Use the coax as output to the antenna input of the RF modulator, and the A/V jacks of the DVD player to the A/V jacks of the RF modulator. Hopefully the modulator allows the A/V jacks to have priority over the coax input, so that when the DVD plays it "wins"
Jan 12, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
