Question about Kenmore 63942 Dryer
Burning smell & Soot
My daughter put just a few dry clothes in the dryer to de-wrinkle them and after a few minutes there was a burning smell (like fire) and there was what appeared to be black soot in the lint tray. Help???
  • Anonymous Mar 14, 2014
    my clothes have more wrinkles when they come out of the dryer than when they went in. how do i adjust the settings to reduce wrinkles?
  • 943 Answers
Thanks for the question It looks like a piece of clothing caught fire The back felt around the drum at back must be worn dismantle and vaccum out if the felt is worn badly it will allow clothes to slip through THanks for the question The appliance doc
Posted on Sep 11, 2008
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
How can I get less wrinkles in my clothes after wash cycle is finished?
I use the dryer to get the wrinkles out. If i have a wrinkled shirt that is already dry and I need to wear it, I put it in the dryer for a few minutes with a wet wash rag.
Oct 10, 2014 | Kenmore Washing Machines
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Burning chemical smell coming from the gas dryer
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
May 28, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Mar 07, 2009 | GE Dryers
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Kenmore 63942 Dryer Logo
128 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
