Question about Cameras
I am using an Olympus E-500. and am trying to use the built in flash, set to one eight or to one sixty fourth of normal output, to trigger an external flash unit. The camera is set to "Vivid", manual, auto focus, and iso 100. From the "manual flash" menu I should be able to select either full, 1/4. 1/16 or 1/64 of the output. However, those choices never light up. I keep cycling through the first two lines of the menu and never reach the third line with the light output options I want. Please advise. I need some authoritative help. David W. Cugell, MD
  • 2 more comments
  • David Cuge;; Jul 20, 2008
    I am thankfu; for the advice, but it would be a bit more helpful if I could be told what to do, rather than just where to go to look for the necessary information. I have the advanced manual, printed in China in 2005, and have tried to follow the instructions, but I still cannot display the reduced flash light output I would like. I am shooting in the macro mode. Thank you.
    I connot understand what I am doing that is incorrect. I just cannot get the bottm row of choices that are shown in item @ on page 54 of the advanced manuual to light up. Rotating te control dial cycles through the four choices in the first
    two lines, but never illuminates choices in the third line. I have the mode dial set to M, iso to 100, and flash to fill.
    Your manual, for those of us who need a second one, is very impressive. I am very glad to have it Unfortunately, I cannot get to the "full, 1/4. 1/16 1/64" line on the Flash Mode screen/
    In spite of numerous suggetions that I read the manual I am still doing something wrong because I just cannot
    get the bottom row of choices that appear on the "Flash Mode" screen to light up. Rotating the control dial cycles through
    two lines, but never illuminates choices in the third line (full, 1/4. 1/16. 1/64). I have the mode dial set to M, iso to 100, focus to S-AF. and flash on (no red eye, 2nd curtain etc)..
    Sergeant:
    Champion:
  • 221 Answers
You should consult a Professional Photographer / Cameraman or contact the Customer Care of the Company.
Posted on Jul 28, 2008
  • 813 Answers
See the manual of cmaera
Posted on Jul 20, 2008
  • 2,071 Answers
Have you read the manual, front toback? In low light, the E-500 fires a burst of flash to help focus. Many of thecheaper DSLRs do this. I think it soundslike you have the red-eye feature enabled and are attempting to take a picturein low-light conditions. As was mentioned earlier, spend some time with themanual and learn each of the features on the menu. Good luck, and I can assureyou that once you become familiar with your camera you will love it. It reallyis an excellent camera and can hardly be beat for the price.
A picture guide and information availablehere:
http://www.wrotniak.net/photo/oly-e/e500-using.html
It's sort a like the manual after you have read the manual. A must read forany E-500 owner.
Hope this help;
    Genius:
  • 1,665 Answers
Have a look at setting instructions at your manual
    Master:
  • 382 Answers
The menu is divided into five "tabs": shooting 1 & 2, playback, and custom 1 & 2.. In your menu option choose "Shooting menu 2" option ..Please select that option only in which you will be able to choose the "Flash power (Full, 1/4, 1/16, 1/64) - only displayed in S or M mode"..THank you
Please post how things turned on or for further help..Regards!!..
  • 3 more comments
  • Natesan Sabesan
    Natesan Sabesan Jul 20, 2008
    Also the whole options in Shooting Menu 2 is as follows
    Shooting menu 2:
    • Flash mode
      • Setting
        (Auto, auto w/redeye reduction, slow sync w/redeye reduction, 2nd
        curtain slow sync with redeye reduction, flash on, flash off,
      • Flash power (Full, 1/4, 1/16, 1/64) - only displayed in S or M mode
    • Flash exposure compensation (-2EV to +2EV, 1/3EV increments)
    • Drive (Single shot, continuous, self-timer, remote control)
    • AF mode (Single AF, continuous AF, manual focus, single AF + manual focus) - I described all of these earlier
    • AF (S-AF, C-AF, MF, S-AF+MF, C-AF+MF) - I explained these earlier
    • Focus point (Auto, left, center, right)
    • AE
      bracketing (Off, 3 frames/0.3EV, 3 frames/0.7EV, 3 frames/1.0EV) -
      camera takes three shots in a row, each with a different exposure
      setting
    • White balance bracketing
      • Color (Red/blue, green/magenta)
      • Shots (Off, 3 frames/2 steps, 3 frames/4 steps, 3 frames/6 steps)
    • Flash bracketing (Off, 3 frames/1 step, 3 frames/2 steps, 3 frames/7 steps) - same idea as above but with flash exposure
    • Manual
      focus bracketing (Off, 5 frames/1step, 5 frames/2 steps, 7 frames/1
      step, 7 frames/2 steps) - same as above but with focus
    • Anti-shock (Off, 1-30 sec) - keeps the mirror open so its movement doesn't blur your photos
  • Natesan Sabesan
    These images are for your further assistance Buddy!
  • Natesan Sabesan
    This is the image of Main menu!..
  • Natesan Sabesan
    Hello again,
    As described in the picture earlier press your menu option once..Then move to the second option on the Extreme Left,which is "Shooting menu 2" ..Now in this menu,you will have the first choice as "Flash Mode Setting" in which you have to choose "The Manual flash exposures"in which you set values like Full, 1/4, 1/16, 1/64 ..
    Hope this helps you out!!..Thank you!..
    Regards!!..
  • Natesan Sabesan
    Natesan Sabesan Jul 28, 2008
    Well In The Flash MOde the Flash power (Full, 1/4, 1/16, 1/64) - are only displayed in S or M mode only..So make sure you dont have any other mode because this is the only reason due to which your THIRD option is not being highlighted...
  • 2,427 Answers
Your settings are wrong
here is the advanced user manual it will describe everything you need to know
http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf
I can safely say the mode you desire to use is cause of the default settings you need to turn on and off other specific things in order to archive the flash settings desired. NB the advanced manual contains more indebth information than the one shipped with the camera you may want to consider saving the link
or a copy of the pdf file, you will need acrobat reader to view it
  • 1 more comment
  • Rishi Roshan Ali Jul 20, 2008
    example the modes aviable in C-AF and S-Af etc are quite different, the method i may give to get these options may not be exactky what you want , by using the ADVMAN you will be able to have it set to your desire
    Ok so he posted something that he copied from the advanced manual link i posted above
    1 set the camera to manual
    set the focus to manual
    now you may use your desired flash settings.
How do you synchronize a non olympus flash unit to an olympus e 500
Install flash on hot shoe and use shutter speed on camera set to no faster than 1/125. Read the owners manul for flash AND camera. Be careful, some trigger voltages may be higher than what your cdamera can handle and may ruin internal flash usage, if not camera itself. better to use a Wein Safesynch hot shoe. This mounts ion hotshoe of camera and flash is attached to this.
Dec 30, 2010 | Olympus EVOLT E-500 Digital Camera
Internal flash not working on olympus e500
The Xenon flash tube in modern strobes rarely 'burns out'. I would guess that a switch that is activated when the flash pops up is not working properly. More info can be found here: http://forums.steves-digicams.com/olympus-dslr/159660-e-500-built-flash-not-working.html
Dec 08, 2009 | Olympus EVOLT E-500 Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
Olympus E-500 - Flash not working at all
you will need to try to reset the camera first through the camera menu by placing the camera mode to P, press menu, right arrow to card, down one to custom reset, right arrow, ok, yes to reset. else you will need to send to repair center
Oct 06, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus E-500 flash smelling like burnt plastic
You should contact Olympus about this.
Olympus have had a recall on some older 35mm film cameras for problems with the flash circuit.
Please see -
Olympus Recall
http://www.olympusamerica.com/cpg_section/cpg_recall.asp
Hope this helps,
Vincent
Jul 08, 2008 | Olympus EVOLT E-500 Digital Camera
Camera does not take pics
I have had trouble with this and what I found is I was pushing on the white balance button at the time I was taking the photo. Try making sure your finger is not touching anything else.
May 26, 2008 | Olympus EVOLT E-500 Digital Camera
Any settings that must be set before you can use the external flash feature
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-20/FL-40/FL-50 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Settings that must be set before you can use the external flash
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built- in flash and the Olympus FL-20/FL-40 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Difference between the D-460 and the D-450 Zoom digital camera
The D-460 Zoom shares the following features with the D-450 Zoom: •1.3 megapixel resolution - 1280 x 960 pixels •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •2x digital telephoto mode •3x image magnification inspection mode •Sequence mode: Up to 10 images at 2 frames per second intervals (SQ mode only) •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self timer •8 MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings (125, 250, 500) •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-460 Zoom has the following functions and features: •Industry standard icons for button labels and operation menus •Easy to use jog dial and button design allows easy menu navigation •2 compression ratios are now selectable in SQ mode •Selectable Sharpness: Normal or Soft •Selectable Memory Mode Setting: Reset camera settings at power-off or Retain all camera settings •2 Olympus brand CR-3V long life lithium batteries included. Provides 20-30 times the power/life of alkaline batteries
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Cameras Logo
95 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
