Cars & Trucks Logo
Posted on Jan 31, 2011
E-Check Light P0125 and pending p1153/p1155. Replaced ECT and codes reappear. Where is this Bank2 Sensor1 located on my 1998 toyota camry v-6 auto with air. P1155Code book described as AF sensor.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 31, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1227
Points
5
Air/Fuel Sensors are mounted upstream of the catalytic converter. They are located on the exhaust manifold side of the catalytic converter (pre-converter - Sensors 1). Oxygen Sensors are mounted downstream of the catalytic converter (post-converter - Sensors 2). The catalytic converter has two chambers (left and right). Bank1 is left, drivers side. Bank2 is right, passengers side. The Bank2 Sensor1 sensor (Air/Fuel Sensor) is the one located on the 'right and ahead' of the converter. The PowerTrain Control Module (PCM) is reporting that the heater or circuit ( wiring / plug-in) of the sensor is malfunctioning.
I have Toyota Rav4 2001, check engine light on with the error code P1155 and replaced the oxygen sensor about a week it ran with no error. After a week another error came with a code P0125 and p1150.
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
2answers
1999 toyota camry xle 3.0 liter after changing the o2 sensor the thermostat it still gives me the same codes p0125 p1135 p1133 p1153 why
Then it is time to consult an expert local shop. As you have learned no doubt that throwing parts at the problem gains you nothing.
How to repair P0125 for 2000 Mercury Mountaineer
P0125 OBD-II Trouble Code Technical Description Insufficient Coolant Temperature For Closed Loop Fuel Control What does that mean? This means that the engine coolant temperature (ECT) sensor indicates that the engine has not reached the required temperature level to enter closed-loop operation within a specified amount of time after starting the engine. Symptoms You will likely not notice any drivability problems. Causes A code P0125 may mean that one or more of the following has happened: Insufficient warm up time Low engine coolant level Leaking or stuck open thermostat Faulty coolant temperature sensor Possible Solutions The simplest thing to do is to reset the code and see if it comes back. If the code comes back, the problem is likely going to be the result of the above causes (faulty thermostat, faulty ECT sensor, or a low coolant level). Other ECT sensor and circuit related DTCs: P0115, P0116, P0117, P0118, P0119, P0128 Register now to ask a question (free) Related P0125 DTC Discussions 1996 chevrolet Caprice p0125 Car start properly but after 5 or 10 minutes driving start doing missing and stop. After that car will not start but 20 minutes it start but again stop, if you just start the care and don?t drive it will start 24 hours with no issue but if you will go for drive than you will stuck in middle of the r... P0125 on a Saturn Sc1 My grandpa's car has a p0125 check engine light on. Tha car will not start and is running rich on fuel. We tried replacing the fuel pump and filter, fuel injectors and even the coolant temp sensor and it didn't work. What else can it be? Here's the code. P0125- closed loop fuel control insufficien... 1997 corolla engine code p0125 Im getting code p0125 in my 1997 corolla and have changed thermostat coolant temp sensor and have topped up coolant level but code keeps reappearing any sugestions would be appreciated.... 2000 4runner P0125B code Engine light came on. Local garage read code as P0125B. Internet search says engine coolant temp. sensor which I will replace. Where is it located on 3.4L engine?... camaro codes p0404 p0505 p1404 p0304 p0122 p0125 Hey I got the codes when I ran my test p0122,p0125,p0304 P0404,p0405,p1404 was wondering what's all that and the price or it better to replace the motor...
Read more at: http://www.obd-codes.com/p0125
Copyright © OBD-Codes.com
1helpful
Where is lockation of trouble code p1155 in camry2003
Bank 1 sensor 2 that would be ft manifold botton sensor on manifold the second sensorthanmkyou also you need to check
to see how much air come out of 02semsor hole because
if you don't replace right away the converter. Melts and needs to be replaced also
good luck and plaese4reply
Where is the ECT sensor located on my 1999 Toyota Camry XLE 6 Cylinder?
On the 1MZ alloy block V6 it is on top between the engine coolant filler cap (not the one on the radiator) and the dogbone engine steady bar.
If you want more info, post here an email where I can send it to you 50e82e93-93a5-4332-aa03-0149de5ebb67.jpg
I have a 2000 Camry - 6 cylinder with about 180,000 miles on it. The Check engine light came on and it showed three codes - P0125, P1130 and P1135 - We put in a new thermostat - and still the check engine...
Was the computer reset after the thermostat was replaced?? If not, it must be reset to clear prior codes. as for the p1130/1135, they are related here is some info>>>>http://www.engine-light-help.com/toyota-engine-light.html
9helpful
3answers
The Toyota Camry engine light is on. Error Code P0125
Change bank 1 sensor 1 this will solve your problem. Tihs is a fuel issue nit a thermostat issue.
1helpful
More indepth explanation of scanner codes for 98 Toyota Camry
All of these codes are for a bad A/F sensor (O2 sensor) bank # 1 sensor # 1 nothing to do with spark plug of gas cap. Replace this sensor and your code will go away.
2helpful
Oxygen sensor need to know where bank2 sensor one is located
Bank 1 is the same side as cylinder #1 and bank 2 is the same side as cylinder #2. Good luck and hope this helps.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
