Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Big screen out of focus
Magnavox big screen rear proj. Pic . a little blurry. But when words appear on the screen their double. How do you focus?
  • ronniephel Jul 21, 2008
    my tv has poor color display if i tried to adjust the brightnes the night parts of a show is to dark. how can i fix the colors so they are bright but now too white background
  • truckertexas Jul 25, 2008
    i went into the back and tried to make adjustments from color adjusters but, that did,nt work.
Have the fluid changed in the bulbs, I have the same TV and this made a big difference, although some say it's a gimmick. I saw the fluid that came out and it wasn't pretty-
Posted on Aug 26, 2008
    Master:
  • 726 Answers
Ok you have to open the tv intill you see the 3 bulbs and the big mirror
the around each bulb is a wheel u have to turn that for the pic and focus
Posted on Jul 20, 2008
Does it take some type of gel under the lights, the colors are a little blurry
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
Blue color
On front bottom panel remove behind it will be your focus/screen block cobtrol adjust Blue screen drive and focus also how to enter service mode for convergence with set off PRESS and hold at same time ch-&vol- untill set comes back on release you should now be in service mode for convergence.
Feb 19, 2009 | RCA D52W19 52" Rear Projection Television
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
Magnavox rj8510 ak03 out of focus?
Thats your focus/ screen control block good luck on finding one.
Oct 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
52" philips magnavox
theres focus controls inside the rear of the set on a small control panel with 6 dials 3 control the screens, and the other 3 control the focus for all three tubes.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Blurry partial picture on a 42" rear proj tv
There may be dust on Lamp or at front screen. why dont you open rear cover of TV and give a close look?
May 28, 2008 | Sony KP-51HW40 51" Rear Projection...
Green screen
It sounds as thought the lower light strip has malfunctioned & blown the red/blue LED lights leaving only the green bulb functioning, I would ring the makers repair team for a repair if it's under warrentee or a repair quote, if warrentee has expired, from my personal experience showed me that a new TV is cheaper. I hope this helps.....
Feb 21, 2018 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
250 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
