Canon NP 6650II Copier
Problem for Canon NP 6650II Copier
Canon 6650 E010 error
By XwyhyX on Jul 20, 2008
help,i keep getting this error when trying operate the machine. Any help would be grateful,
Comments:
Jul 23, 2008
- hmm my technician took the motor out and said it was broke, dumbo sized paperclips? those in the machine?
Best Solution
posted on Jul 23, 2008
Helpful)
spinal
Rank: Guru  Canon Expert
Rating: 90%, 274 votes
uhhhh, wow. That is a main motor lock error code. As in the main motor is bound up and cant move because of a physical bind or the motor has taken a dirt nap. Very rare code. I have been working on Canon machines for 20+ years and only seen that once. One of those what I call "DUMBO SIZE" paper clips truly kept the motor from turning. GFL.....
Comments:
Jul 24, 2008
- Hello Xwy
I just went to and am currently reviewing the"FIXya" website and noticed your response. I would like to clarify. First, The "dumbo clips" I was referring to are the biggest paper clip you'll see. They have set of conntact areas that are quite large and I have also heard them called "butterfly clips, referring to the "wings" that I thought looked like the ears of an elephant(dumbo). Typically foriegn objects like this accidently fall from the copier glass or document feeder area down to the bypass tray located on the right of the copier. This tray was meant for heavy stock paper or transparencies. It is often left open,and is a convenient way for foreign objects to enter the paper path as folks prepare their documents for copying. They stand over the machine and remove staples and clips, and if the bypass tray(Canon tends to call it a MULTI FEED tray) is open any stuff from above can fall into the bypass tray and get gobbled up by the copier. But the bottom line remains the same. The main controller of the copier sees that the main drive motor is not operating which means the motor died (rare) or some foriegn object has bound the main drive up to the point that the motor cannot operate properly. I just wanted to take a moment to better explain the "DUMBO" thing. I wish you the best.
Was this helpful?
Yes
No
Popular Solutions for Canon NP 6650II Copier
Questions and Unsolved Problems for Canon NP 6650II Copier
Do you recommend Canon NP 6650II Copier?
Answer
Answer
my printers cradle is stuck
Answer
Printing legal size letter
Answer
My casio sf5300 has not been used or about 3 years, so I replaced the batteries but it will not turn... (More)
Answer
how to increase the intensity of black when using an oki c3530 mfp printer
Answer
shaky image on top of page (One inch below) on every copy
Describe your Copiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in , MD
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
