Optoma MovieTime DV10 Multimedia Projector Logo
Anonymous Posted on Jan 31, 2011
Remote as broken need to know were to get replacement and at wat cost for optoma dv10
Anonymous
Level 3:
  • Master 488 Answers
  • Posted on Jan 31, 2011
Anonymous
Master
Level 3:
Answers
488
Questions
0
Helped
231259
Points
1359
Http://www.remotes.com
Unit will not power on. replaced lamp, same result optoma movietime dv10
please Check Lamp Cover and Interrupt Switch
- Ensure that all connectors are securely connected and aren't broken
- Check LVPS
- Check Lamp Driver
- Check Main Board
2answers
2answers
DV10 Color Wheel Replacement
Hello, the information is as follows:
Part no: 70.18r26g01
Cost: 129.00 + shipping
Model :Optoma DV-10
Contact no: (408) 383-3710
You may also contact the "out of warranty" repair department at 888.942.2929.
Glad to help.
5helpful
2answers
Optoma dv10 color wheel
Sure! I already answered your request, but here goes.
Part Number : 70.81r26gr01
Cost :$129.00 + Shipping
Part : Optoma DV-10 color wheel replacement
Shipping is around $18.00 Ground, $35.00 2- day, $55.00 overnight.
Tel no. :408.383.3710
This information was current as of posting date.
15helpful
5answers
Optoma DV10 color wheel
Okay, I recently had a loud noise coming from my projector and found online meterial stating that the colour wheel had been damaged. So with a bit of guts I managed to open the projector and found the colour wheel missing a segment.
I removed the colour wheel and the broken piece of the segement and tried to contact Optoma. Optoma turned round and said they cannot sell me the the colour wheel, which got me very upset. Some people claim online that Optoma will sell you the part on a back order at £50. (if you can be a little specific on how you managed to convince them to sell you the part, would be great).
The only option I had available was to send my project to them and they would repair for an estimated cost of £125+VAT. Guess what, you can buy the entire projector off ebay for 150quid!!!
Anyways after fiddling around quite a big online I got fedup and decided to glue the broken segment together and it SOLVED the loud vibration problem. I have colour and picture.
Becareful not to tighten the colour wheel screw too tight orelse it will break another piece of segement (Like I did).
Here are instructions on how to open up the projector.
http://www.geekfest.info/DV10/dv10.html
I cannot guarantee this will work for you as it depends on how badly you have shattered the colour wheel segment, so do at your own risk. I had two piece of the segment broken and a third by tightening the colour wheel screw too tight.
This will work for awhile but the colour wheel does need replaceing one day. If anyone can tell me how you can get Optoma to sell you the colour wheel would be great.
Best of Luck
1helpful
2answers
Bad color wheel on Optoma DV10
Yes, you can replace the color wheel yourself if you are handy with a screwdriver.
1helpful
2answers
I do not know remote control code.
need help programming the RCA 3273 remote
2answers
Optoma color wheel
Hi there
You could get one from a Optoma agent.
I can unfortunately not tell you exactly where as I do not know where in the world you are .
3helpful
4answers
Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
Optoma dv10
Hook the coax line into a source with a built in tv tuner line a VCR or an LG DVD Player/Recorder.
Then run the connect the picture output from the source to one of the Optoma's picture inputs.
Use the source's remote control to flip channels.
If you want to use the Optoma's speakers too, then just run the audio outplugs into the Optoma's audio input. Done.
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
