Question about Samsung SyncMaster 753S 17" CRT Monitor
Width increases a bit on lowering and incresing resolution
I lowered resolution but the problem remains. amazingly when i went back to 1024x768 from 800x600 the the display width has increased. though it does not fit the screen yet but its wider than before.
the vertical adjustment works fine but while adjusting horizontal i see a faint white line on side edges and the actual display starts at a distance of about half a cm from those lines. so when i try to fit image to the screen i have to push those lines outside the screen.
    Brigadier General:
  • 6,966 Answers
Hence my earlier suggestion of lowering the resolution, it was actually a test.
Now we are getting somewhere. Yoke is definitely out, opposing diode pair is also out. The remote chance of the horizontal sync/oscillator is also out. That leaves us only with a possible resistor that has gone up in value (or is open) (least likely) and/or a capacitor (most likely) that has leaked, bulged or whose capacitance has gone down.
Perhaps a service manual would be of more help.
Good luck.
Posted on Jul 20, 2008
My screen just goes white,I have to press back to get screen on again
Control panel/display Adjust resolution
Change the resolution 1024X768 see if that helps if it does keep going up until it turns white again then lower until it doesn"t
Jan 07, 2015 | Samsung Galaxy Tab 8.9 WiFi 16GB Tablet
The window is lower than the monitor
Right click anywhere on desktop choose "Properties" and then select "Settings" then use the slider to increase the resolution to say 800x60 32bit, or 1024x768 32bit. This will sort you out, if you can't see the Ok, Cancel buttons at the bottom, pressing "Enter" is same as saying "Yes" or "OK" ESC, is "Cancel" If it is not that then maybe you need to use the buttons on the front of monitor, one button is for Menu, the others scroll you through various settings, another will make that setting increase or decrease.
Feb 22, 2010 | Computers & Internet
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
HP DL380 G4 Video resolution
I'm afraid that the server video cards on these are pretty poor, the only way to improve this is to add a PCI video card (I added a cheap MX440 to a server I run to get around this). If your PCI slots are all filled up then I'm afraid there's really nothing you can do.
You could TRY to decrease the color bit depth, and see if that helps. Often the video drivers don't support detecting when a higher resolution is possible due to a lower bit depth, or the cards don't actually use less storage for them. (the problem is a lack of RAM on the card to hold a full screen full of pixels at a higher resolution.)
Jan 16, 2009 | HP Compaq ProLiant DL380 G4 Server
Screensize of acer 5670 laptop
Yes the TV could have changed your screen settings (probably to 640X480 resolution).
Go to the Control Panel, then click on Display, then the Settings TAB, then change the Screen Resolution to at least 1024X768 pixels or higher to suit your requirements.
NOTE :- The higher the resolution the smaller Icons and text will be displayed also a lower color quality display ie the best is 32 bit color.
Jan 13, 2009 | Acer Aspire 5670 Notebook
Screen Resolution
Tried Control Panel and went into Appearances and Themes and then on to Screen Resolution.  Discovered this had been set at low, so I simply increased to download disc and then reverted back to lower size.
Dec 26, 2008 | Canon COLOR IMAGE SCANNER
Windows vista lare icons and text
In changing the icons to normal, did you reset the screen resolution? If not, set the resolution lower, apply, then reset it back to the original (usually 1024x768), then apply.
Aug 12, 2008 | Toshiba Satellite P105-S6207 Laptop
Cannot change resolutions.(monitor)
This could be caused by a variety of problems:
1. The video/graphic card does not support that resolution because:
a. it does not have sufficient display memory (at least 2 or 4 megabytes is requiered, if you don't have this amount buy a new video card)
b. the video card driver has not been installed properly or is corrupted (reinstall the video driver)
2. The monitor does not support 1024x768 resolution
Change your resolution, follow this procedure:
Please provide your entire system specifications, including the monitor.
Dec 21, 2007 | Intel D915PCM Motherboard
Sanyo Projector==No signal
Hi, Perhaps you can try lowering the screen resolution first of the laptop before plugging in the projector and then the Fn + F8. Thereafter, gradually increase the screen resolution until projector stops displaying. The idea is that your current screen resolution maybe too much for the projector to handle. This of course is assuming that there is no hardware problem with the projector. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 10, 2007 | NEC MultiSync GT1150 Multimedia Projector
Samsung SyncMaster 753S 17" CRT Monitor Logo
107 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
