Question about Samsung SyncMaster 753S 17" CRT Monitor
Display rotation display rotated by 90 deg clockwise. how to fix it?
  • 21 Answers
Fixing this is rather simple. Depending on what card you have, you'd need to get to the relevant section within the Advanced Display properties to access a "Rotation" settings page.
Here we go:
  1. Go to Start > Control Panel
  2. Double-click on Display - accesses Display Properties
  3. Click the Settings tab
  4. Click then Advanced tab on the bottom right hand corner.
  5. You'd then see another pop-up property page. Click through the tabs and see if you can find any options/tabs which take you to Display Settings.
  6. You'd then find "Rotation" - from which you'd need to select / apply the required rotation to get it back to normal.
Hope this helps. Do reply in case you need further help.
Thanks!
Sincere-One
Posted on Jul 20, 2008
Hi , can you tell me what is the torque settings for Main,biggens and head bolts for Opel combo 1.4 16v 2006 model z14xep motor?
STANDARD TYPE GM ROD BOLTS
STAGE 1---18 LB/FT (GRAPHITE GREASE UNDER HEAD, OIL THREADS)
STAGE 2---30 DEG's additional bolt head rotation.
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---70 LB/FT
STAGE 3---15 DEG's additional bolt head rotation.
CYLINDER HEAD BOLTS for standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE SEPARATE SHEET FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---90 DEG's additional bolt head rotation.
STAGE 3---90 DEG's additional bolt head rotation.
STAGE 4---90 DEG's additional bolt head rotation.
STAGE 5---45 DEG's additional bolt head rotation.
Nov 06, 2016 | Opel Cars & Trucks
The pump will operate for 5 to 10 seconds and stop. 2 or 3 minutes later it will pump again for a few seconds. It takes a long time to drain the machine.
Drain the machine. Then turn power is off at the wall socket. Then tip machine back against the wall as far as you can. Get down under front right of machine & remove the wires going to the drain pump. Next remove the drain pump by turning it 90 deg clockwise. There is a white clip near the top edge of pump on R.H. side - hold that out while you turn it. Once it is out check pump & up in the pump outlet hole for obstructions. Put pump back with wiring plug facing R.H.side of cabinet then rotate 90 deg anti clockwise. Re attach wires and stand machine up.
Jan 04, 2016 | Fisher and Paykel GWL11 Top Load Washer
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Pictures upside down
right click on the picture and select rotate clockwise, it will do it 90 deg at a time, so do it 2 times and your picture will now be right side up..
Hope this helps
Roger
Feb 08, 2012 | ASUS Computers & Internet
F 20 error message
F 20 errors are presented by front loading washers that have debris in the filter sreen / pump inlet area. Open the lower panel... have something like a cake pan and mop ready then rotate the 5 inch circular piece CCW 90 deg and pull it out. This is the filter. Clean out the screen.. then look inside the cavity and remove any debris in the cavity paying particular attention to the pump inlet. Once clean press in the filter and rotate it 90 deg clock wise. Close the lower panel and reset the machine. Test for leaks....
Thanks for choosing FixYa,
Kelly
Jun 16, 2011 | Kenmore Washing Machines
How do you change out water filter?
Hi and welcome to FixYa, I am Kelly
Press in hard.. rotate it 90 degrees Counter clockwise and wiggle / pull it out. When you re-install a new filter align the filter with the internal locking tabs and press in hard and rotate 90 degrees clockwise.
Some times the filter can br really fussy to remove you just have to keep wiggling and pulling to get it out of the recepticle once you have rotated it 90 Deg CCW.
Kelly
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Screen Rotation problem
To revert the screen to normal upright position, press these three keys together:
ALT CTRL and UP Arrow key.
(See attached image)
Hope this solves your problem. Thanks for using FixYa.
Jun 12, 2010 | Acer X193W LCD Monitor
On power up the display is rotated 90 degrees clockwise
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel ->dispaly ->settings.
Find Graphic property and like Intel Graphic Media then go ot it's display settings Then rotation enable Rotation and set 0 degrees.Then apply and ok.
Let me know if you need further assistance.
Dec 04, 2009 | Dell Latitude D630 PC Notebook
Screen image rotated through 90 deg.
Hello , friend
Please do this shortcut
ctrl + alt + arrow keys
Jul 26, 2008 | Lenovo ThinkPad T61 Notebook
How can the image be rotated?
To rotate a vertical image, display the image in playback mode, press the down key to cycle through the three positions: 90 degrees counterclockwise, 90 degrees clockwise, and horizontal. Upside down position is not available.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Samsung SyncMaster 753S 17" CRT Monitor Logo
168 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
