Back to:
Canon MV800i Mini DV Digital Camcorder
Camera not detected
posted by julian2ad on Jul 20, 2008
I have the same problem. Same camera. I got a new Dell Inspiron - which has a 4 pin firewire input. The canon came with a 4 pin to 6 pin cable. So I got a 4 pin to 4 pini cable but my comp still doesn't recognize it. Using Vista.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 25, 2008
Not Rated (0)
krisrue
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had this prob too and it turned out that the settings on the camera had been changed. All I had to do was make sure the setting were AV->DV off in the VCR (play) menu
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on camera not detected:
I don't want to Accept this solution
Can you Help with these Camcorders problems?
When wanting to view the film I just made on my camera, it...
I have the same problem. Same camera. I got a new Dell...
when i try to load a tape it does not accept it then...
My Camcorder was charging as per usual - i went to use it...
Loading problems.
Repair Service
Find Camcorder Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
